87 Crx sleeved h2b turbo swap build...
Just bought an 87 hf crx suuuuper clean for 400$
Guy just gave up on the car.
It has/had till today......
Place racing bseries swap mounts
Hasport swap axles
Custom shift linkage for b swap
B16 cable trans on b18a short block gsr pistons std bore (knocking) yay! Lol
Act maxx xtreme clutch 4puck unsprung w fidanza flywheel.
Has 3 i think gallon cell aeromotive a-1000 pump -10 lines filter etc.
Its gutted just drivers seat. Guy said it went 11.7 with stock b16 head and 50 shot.
Anyway i pulled the bad ls block/trans out
Bolting b16 trans to my hlong block tmw.
Im cutting upper and lower radiator support on car and square tubing it further out on bottom for downpipe clearance.
Onto the build...
H22a4 darton wet sleeved scat crank eagle rods je 9:1's arp mainstuds
Arp headstuds ferrea .5mm over valves type s cams supertech s and rs
Venom style obx crap rewelded manifold golden eagle rail id 1000cc injectors
Peakboost tubular mani power master super t70r chinese turbo tial 38mm wastegate tgi 3" downpipe QUARTERSPORT h2b ef kit act maxx xtreme clutch fidanza flywheel hondata s300j. Using the stock chassis wiring for lights and signals then splicing in ek subharness 99/00 w ef fusepanel for engine w rywire jumper harness. Anyone know how to post pics? Also im doing 03 civic hybrid cluster in a dc dash corbeau racing seat ds and crx si 2g pass. Hoping around 17-1800lbs with me in it.
Hoping this is faster than my 89 crx dx built b20 eagle rods crank wiseco pistons fully built crane ls/b20 head stage 3 turbo cams vic x custom top mount w precision 6776rs dual bb turbo tial mvr tial q bov precision fmic 3.25" dp etc injector dynamics 1000's walbro 400 this one is kinda show and go jdm zc hood legit spoon cam gears greddy tbelt toda flywheel hasports etc
Also how can i post pics? I have a gay cardomain is there an easier way
Hasport swap axles
Onto the build...
Sounds like fun, you'll be only the second h2b in a first gen. you can make a photobucket and post img codes directly to here.
Nice build. Shouldn't be too hard to do the drivers side. prob just slight nods to the H2B drivers mount adapter.
Good luck with it!
BTW for pics just edit the post, then scroll under where you type and there will be a "manage attachments" button. click that and a pop up will come up which will let you upload pics.
Good luck with it!
Pics!!!!!
Hopefully they work
http://m1267.photobucket.com/albums/...PRA6R61Za84%3D
Theyre out of order shows when i got the car with bad built ls swap then empty engine bay to mocking up process now
Hopefully they work
Mine is completely overkill. Thats the name my friends and i have dubbed for this project haha. Had to grind down my drivers motor mount bracket to clear my tbelt. Doing that for personal plate "overkil" the quartersport ef/da bracket just needed two min of grinding to work in two spots.
88crxvtec
Nov 29, 2008 02:13 PM
RyanA
Jan 21, 2007 07:24 PM
