94 Gsr Motor into 93 hatch
I am doing a gsr swap b18c1 the motor is a 94 into my 93 hatch that had a d16y7 motor and I am wondering if i can use the factory harness to wire up the motor. Also I am pulling the motor out now and the left hand axle doesn't seem to want to come out how can i get that out??
if you put a puller between the between the transmission and shaft end i think i well let go by force because the end axel has a pin in the tranny that maybe is off-site
if the hub if hard to let go use a grip strength and a long tube to increase the twist
The trans side is easy. You have the entire housing to use a a base for prying the axle out. My technique is to give it 3 or 4 fast prys (dosent take a whole lot of pressure), then spin the axle by hand and pry some more. Keep spining and prying, eventually the ring clip will give..
jdmeg6honda
Aug 13, 2011 04:00 PM
TheMostSadistic
Apr 24, 2003 11:15 AM
