Fan issue
Hopefully I don't get flamed I did check the search but couldn't find any issues like mine. I drive a 1989 Crx with a JDM b16a swap. Now for the fan, it doesn't turn on when the car gets hot. It turns on whenever it wants to. I let the temp get to about 90 percent just to see if it would turn on. But it didn't. So then I turn the car off and put it in the on postion and the fan went on all of a sudden. Weird right? Then I turn the car on again(motor running this time too) and it still is running. Then after it cools the car down it shuts off and won't go back on again. I heard the relay clicking, everything seems to be grounded properly. Any idea's?
Start here^ by topping off the radiator and reservoir with coolant and bleeding the cooling system.
If that doesn't help, then unplug the fan switch and jump the connector with a wire or paperclip to see if the fan now runs continuously. If so, replace the fan switch.
I replaced the temp thermostat already. There is no air in the system. I already bled it. And damn I realy didnt want to have to replace the switch cause its all the way at the back of the block haha.
EFOwNzALL
Jun 24, 2008 09:09 AM
