Honda CR-V & Element 2WD & 4WD Element & CR-V
01 crv flashing CEL.
Old Aug 14, 2012 | 06:16 PM
skylinerb26dett's Avatar
Default 01 crv flashing CEL.
Hey everyone. I need some help. I have an 01 crv auto with 166k. Already had the head replaced with one from an integra. Done at king motorsports. Anyway tonight I was driving and it started misfiring like crazy. The CEL started flashing. Then it would turn solid. Then back to flashing. Shaking at idle. Spark
Plugs were replaced. As well as head gasket timing belt water pump. Anyone that can help
Me please!
Old Aug 14, 2012 | 07:25 PM
BJOnewiper's Avatar
Default Re: 01 crv flashing CEL.
It's in limp mode
Old Aug 14, 2012 | 07:58 PM
Originally Posted by BJOnewiper
It's in limp mode
What's the cause? What do
I do
Old Aug 15, 2012 | 04:47 AM
el crapitan's Avatar
check the codes. the flashing mil is indicative of a type A, catalyst damaging, misfire.
start your troubleshooting by scanning for codes. it may point you to which cylinder is effected. or whether all cylinders are effected. which is key in narrowing down the cause
Old Aug 15, 2012 | 04:49 AM
LDForget's Avatar
Old Aug 15, 2012 | 04:02 PM
black0hatch's Avatar
mine was flashing turned out it had low compression in one cylinder from a burnt valve.
Old Aug 19, 2012 | 05:15 PM
already stated that the head was replaced.
Old Aug 19, 2012 | 05:20 PM
BoosterB16's Avatar
mistimed could be your issue since u did replace the timing belt. Was the head machined before u put it on cuase if the deck isnt level you could be having compression and coolant issues
Old Aug 19, 2012 | 05:42 PM
did you check the codes?
tpeter91
Oct 25, 2010 06:33 PM
CivCruise
12
Jul 11, 2009 09:27 AM
DSM_DC5
Aug 3, 2004 05:33 PM
