So I failed emissions...
Old Aug 14, 2012 | 11:42 AM
hondanewbie666's Avatar
Icon2 So I failed emissions...
I have a 93 Honda Ex with a d15b. When I start it I get a strong smell of gas, and yesterday I had an idling problem (my car would shut off if I took my foot off the gas). So revved it up between 5000-7000 rpms to see if that would fix it After I pulled off I noticed a cloud of smoke from where my car once was. My friend and I changed my spark plugs(the old ones were still good), did an oil change, cleaned out the throttle body, seafoamed and put in a new O2 sensor(the old one cause a check engine light) over the last couple months. I took it to emissions, found out my hydrocarbon count was around 575 and co was 1.08. Any suggestions as to what my problems might be?
I'm trying to learn about cars and brands so I apologize for my ignorance,
Old Aug 14, 2012 | 12:12 PM
Former User's Avatar
Default Re: So I failed emissions...
Please post the emissions sheet.
Old Aug 14, 2012 | 12:19 PM
FearSC549's Avatar
Typical emission problem may be related to clogged PCV valve, dirty EGR, air filter, or IACV.
Old Aug 14, 2012 | 02:37 PM
how do i post a pic thats on my computer?
Old Aug 14, 2012 | 03:19 PM
Two different methods are described in the stickies at the top of the forum.
Old Aug 14, 2012 | 03:57 PM
heh... i guess i did it
Old Aug 14, 2012 | 04:18 PM
Whole form?
Old Aug 14, 2012 | 04:41 PM
Old Aug 14, 2012 | 04:51 PM
habanerored06si's Avatar
Shoulda used Seafoam
Old Aug 14, 2012 | 05:55 PM
Sorry. I thought there were more emissions data.
It seems that the engine was swapped because a 93 Civic EX should have a D16Z6. What ECU do you have?
How old are the cap and rotor? Have you checked the ignition timing?
Any CEL codes?
Any exhaust leaks?
Old Aug 16, 2012 | 08:22 AM
My Ecu is an AWN..? I didnt get any codes the last time we checked. Is there any way to tell if my timing is slightly off without a timing light? It doesn't feel like it is but I'm still a noob. I blew smoke again today and I don't see any visible holes in my exhaust but I won't rule out any leaks because I did smell gas/exhaust while I was driving today. I'll be taking it to a shop to have someone go over it 2 days from now.
apryls82
Honda Civic (2001 - 2005)
Sep 1, 2014 02:02 PM
Butterfly69
Sep 3, 2010 08:05 AM
Accord1987
Classic Hondas
Apr 15, 2010 12:58 PM
alex_s817
Mar 6, 2007 05:38 PM
kjou2001
Jun 2, 2004 05:36 PM
