97 dx coupe noisey clutch
OK i have a 97 dx couple that makes an odd noise when cold. when you release the clutch with the car in neutral it makes a whirring sound. once the car is warmed up this goes away. i believe i have a kwmt5 tranny. 194k
i was going to do a clutch and bearings and fly wheel as i'm not sure of the mileage on the current set. i got the car with 145k on it put the last 49k on myself so i figured it was do. besides the noise there are no other issues with the clutch or tranny. changed the tranny fluid about 4 months ago fluid was not bad looking.
i'd appreciate suggestions.
thanks!
thanks!
I have the same issue. But what's even stranger and I can't figure out is why, when my shifter is in neutral I don't hear any noise. anytime i move it, whether it's far right or far left before selecting a gear, I keep hearing a very faint (fshhh...) sound. Any idea's???
ok so i've ordered:
anything else i should consider. this is not an upgrade for performance, but rather my daily driver that does over 1k a week in mileage.
thanks again for the advice.
-Q
- EXEDY 08022 OEM Replacement Clutch Kit
- Timken 102CC Pilot Bearing
- Prothane 8-504 Red Left Upper Engine Mount Insert Kit
- Prothane 8-505 Red Right Upper Transmission Mount Insert Kit
- Timken 614122 Clutch Release Bearing
- ACDelco 388025 Flywheel Assembly
-Q
Noise with foot off clutch pedal is generally input shaft. Noise with foot on clutch pedal is generally throwout bearing. Input shaft bearing replacement requires a full overhaul minus gearsets.
Xxcivic97xX
Aug 22, 2010 07:22 PM
EFinawesomeman
31
Oct 16, 2008 05:31 PM
