Sudden No Start (99 civic)
Yesterday after work my civic drove home fine with no problems,then this morning I tried to start her up and there is no response at all,what can cause this all of a sudden?
Btw,All my maintenance is all up to date
Timing Belt
Timing Tensioner
Camshaft Seal
Front main Seal
Water Pump
A/C Belt
Alternator Belt
Power Steering Belt
Main Relay
Cooling Temp Switch
Cooling Fan Relay
Oil Pan Gasket
PCV Valve
Thermostat & Gasket
Battery
Timing Belt
Timing Tensioner
Camshaft Seal
Front main Seal
Water Pump
A/C Belt
Alternator Belt
Power Steering Belt
Main Relay
Cooling Temp Switch
Cooling Fan Relay
Oil Pan Gasket
PCV Valve
Thermostat & Gasket
Battery
Re: Sudden No Start (99 civic)
Battery is new,but I can swap a battery and see what happens,I'll check if the rubber stopper has fallen out,is there a temporary thing i can do if the rubber stopper is missing?
Just tested out my battery with a battery tester & tested out at 520 CCA,both rubber stopper still intact?Should I scuff up the terminals with a battery scuffer and see what happens?
Have a buddy hold the key in ON(III) while you measure voltage at the starter solenoid. Also measure voltage at the large starter motor bolt with the key off.
Still no luck with my problem,bought a new starter also and it didn't help.I notice when I have the key in the ignition on the on position the battery & oil light seem to be dim,what can that be?
Janet1995
08-01-2013 04:04 AM
Lei Siew Long
09-30-2001 07:12 PM
