Ls/Vtec swap. Vtec not engaging
Old Aug 14, 2012 | 09:17 AM
Manny 77's Avatar
Icon2 Ls/Vtec swap. Vtec not engaging
I recently put a B16a2 head on my 94 integra B18B1 OBD1. i only put the head with a 99 civic si intake all stock, i used the ls head gasket, timing belt, oil pump, water pump, arp bolts. now i installed a sandwich plate to get oil to the head that way (this swap i bought was already running on a b20 end and working fine). my Vtec does not engage and the head make a clacking niose also code 22 is coming on so there is not enough oil pressure to the solenoid. i also removed the oil restrictor from the block, you think this might be the problem im having now??? im running a chipped p28 and the way i wire the vtec was running the solenoid to A4 and pressure switch to d6 and ground. anything im missing here???
Old Aug 14, 2012 | 09:26 AM
kyden's Avatar
Default Re: Ls/Vtec swap. Vtec not engaging
you're not supposed to remove the oil restrictor from the block.
Old Aug 14, 2012 | 09:31 AM
Manny 77's Avatar
I really tought so.. suck i gotta take everything back apart for a plug... thing is that when i did the same swap on a D16 the plug needed to come out so i removed it from the B18 block without thinking of the sandwich plate
BCSi00
Sep 24, 2020 12:09 AM
tlieu88
Oct 3, 2005 11:28 AM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
Trooper
Nov 17, 2003 07:25 PM
kasted1
Aug 20, 2002 09:16 AM
