Making my HX manual
Old Aug 14, 2012 | 04:11 AM
ThatSlowEvo's Avatar
Default Making my HX manual
Ok so I recently bought a '97 HX, the body is Mint which is really hard to find around here. Anyway, I know there are probably lots of threads about doing this, I figure before I start buying parts I'll run it by this community to make sure I'm not missing anything. First time doing this to any vehicle. On to the parts list if I'm not mistaken...
D16 manual 5 speed trans-$200
Exedy stage 1 solid disc clutch-$120
Shifter linkage-$150
Shifter base-$130
master and slave cylinders-$80
I also believe the OBD will have to be somehow modified, am I correct? My dad is a master at wiring and electronics so I can have him re-wire it. Let me know if I'm missing anything and I'm also wondering if I'll have a problem mounting the master/slave cyls etc, if someone can point out any problems I might run into I'd appreicate it.
Old Aug 14, 2012 | 05:09 AM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Making my HX manual
gear stick + boot + ****
clutch pedal and pedal box
clutch line
flywheel
not sure but you might need a new engine mount for the manual gearbox plus the torque mount
Old Aug 14, 2012 | 05:48 AM
HondaPartsHero's Avatar
Technical Hero
http://civic-hx.blogspot.com/
Old Aug 14, 2012 | 07:14 AM
kyden's Avatar
you'll have to make a mount for the passenger side. HX automatics have a weird mount on that side and no one makes a manual conversion mount for it.
Old Aug 14, 2012 | 11:14 AM
Alright thanks guys.
Sean Cirillo
Mar 24, 2016 04:52 PM
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
erck
Jul 2, 2006 11:28 AM
Spinout
Jul 18, 2004 09:06 AM
LudeSi-93
Dec 26, 2002 08:04 AM
