07 Accord tanny swap...2.4l
Re: 07 Accord tanny swap...2.4l
Manual Transmission
Manual Axles
Intermediate Shaft
Manual ECU (For the engine you have)
Clutch Pedal Assembly
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Hard Line
Flywheel
Clutch Pressure Plate and Disc
Shifter Assembly
Manual Shifter Dash peice/surround (not sure if there is a difference between the two in the 07 model year)
Shift Cables
Manual Gauge Cluster(optional)
You will at least need the transmission mount for the manual, not sure about the rear engine mount and bracket, maybe others could chime in.
Manual Axles
Intermediate Shaft
Clutch Hard Line
Flywheel
Shifter Assembly
Shift Cables
Manual Transmission
Manual Axles
Intermediate Shaft
Clutch Hard Line
Flywheel
Shifter Assembly
Shift Cables
Manual Axles
Intermediate Shaft
Clutch Hard Line
Flywheel
Shifter Assembly
Shift Cables
-jacob-
Transmission & Drivetrain
10-31-2008 03:57 PM
