please help! ticking head!
Old Aug 13, 2012 | 02:34 PM
chickenhawk44's Avatar
Default please help! ticking head!
well a couple days ago my valves started ticking, so today i tightened them and when i was had got it all back together it sounded fine, no ticking, and when i started driving it, it started ticking again but not as loud as before, and the the motor is a D16Z6.
Thanks for any help you guys can give me
Old Aug 13, 2012 | 02:38 PM
Dc4LsTeG's Avatar
EK9
Default Re: please help! ticking head!
Sounds like your lmas
Old Aug 13, 2012 | 03:25 PM
untitled001's Avatar
Check your Lost Motion Assemblies
Old Aug 13, 2012 | 03:50 PM
thaks guys, im new to honda's, so if anybody can think of anything else please say.
Thanks.
Old Aug 13, 2012 | 04:11 PM
Built4Battle's Avatar
Did you let your car sit for at least a day before you tightened the valves?
Your engine need to be cold before you do valve lash. What happens is if you do it when it's warm is once you start driving metal expands under heat and it will change the clearance
Old Aug 13, 2012 | 04:32 PM
no i did it when it was just a little warm, i had read before i did it that you didnt want it to cold or to hot, but ill try that tommarow. i guess ill look here first next time lol
Old Aug 13, 2012 | 04:33 PM
keep the help comin guys i really thank you
Old Aug 13, 2012 | 05:29 PM
Yea cuz when it's warm the metals already expanded so whatever clearance you do when it's cold it's gonna change it. I usually leave the car for at least a day before I do it
Old Aug 13, 2012 | 05:31 PM
And it can't be lma's cuz you said the ticking went away after you tightened them. Lma's tick all the time but one way to find out if it's your lma's drive in VTEC and see if it still ticks. If it does it's valves if ticking goes away in VTEC then it's lma's
Old Aug 13, 2012 | 06:53 PM
ok i will try that, but like at idle it will only tick around 2500-3000 and stop, but when im drvin it tick at 3000 on?
Old Aug 13, 2012 | 07:46 PM
Maybe your just not hearing it? Especially if your cars loud but the tick gets louder as RPM goes higher
Old Aug 14, 2012 | 07:13 PM
well i tried driving in vtec and it still ticks, and my lma's are good, but i am the second owner of the car and the guy said that it had over heated once before, but not for long, the fan came unplugged but do you think that could have worped the head a little bit, and over time it has just took its toll on everything?
Thanks for the help
Old Aug 14, 2012 | 07:26 PM
orioncivic's Avatar
id go back and redo the valves when the car is totally cooled down.
Old Aug 14, 2012 | 08:42 PM
yeah thats whats i was goin to try next, but if that doesnt work, idk what, i quess a new head.
gizzerhatch
19
Sep 10, 2008 10:34 AM
eg6turb0
Mar 4, 2005 03:48 PM
rayscar
Sep 16, 2004 02:34 PM
1.7na
May 31, 2004 07:12 PM
