installing rear sway bar onto 95 civic from 97 integra help
so i pulled a rear sway bar off a 97 teg, and plan on putting on my 95 civic coupe dx. i have blox rear lower control arms. can i use the stock endlinks, and just run a bolt through them, and the lower control arm, with a washer and nut? or will i need to get the blox endlinks
No, you cannot use OEM, or even OEM style endlinks.
Due to the **** *** qaulity of the Blox LCA's, the endlink holes are in the wrong spot, meaning, you are forced to use adjustable style endlinks.
shmooly
Apr 23, 2016 03:48 PM
motrayEG6
Oct 21, 2010 07:22 PM
Allurian
Oct 25, 2008 09:09 PM
