DX/Si Clutch compatibility
Old Aug 11, 2012 | 09:25 PM
///Mathew's Avatar
Default DX/Si Clutch compatibility
Just a quick question guys,
My brother has a 91 DX hatch, his transmission is toast, doesn't go into third, pops out of second, etc etc.
We found an Si transmission, so we're going to swap it in tomorrow, my questions is can we reuse the same clutch and flywheel. We replaced the clutch not 12 months ago so it should still be good.
So is the Si transmission a direct swap? No other parts needed? Thanks in advance.
Old Aug 11, 2012 | 09:58 PM
dickdragon's Avatar
Default Re: DX/Si Clutch compatibility
Should bolt right up with your existing setup. Lucky u found a si trans. I want one bad
Old Aug 12, 2012 | 01:37 AM
whited's Avatar
CRX God
The years matter not the model. 88-89 vs 90-00. One is 21 spline and the other is 20 spline I can't remember which is which. The clutch disk is actually different between the years.
I have a 90 dx tranny in my 88 si, but I used a 96 flywheel and clutch.
Old Aug 12, 2012 | 07:49 AM
///Mathew's Avatar
Hmmm...I believe the tranny we got is a 91. Is there any way to check on the case?
Thanks for your help guys.
Old Aug 12, 2012 | 08:03 AM
pfsmith99's Avatar
This is probably what you need:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
Old Aug 17, 2012 | 11:40 AM
whited's Avatar
CRX God
Count the splines.
Old Aug 17, 2012 | 12:10 PM
Nooch's Avatar
Old Aug 17, 2012 | 11:18 PM
///Mathew's Avatar
Thanks guys, we did the swap last weekend and everything went great.
Canadian_EF
Nov 3, 2010 09:15 PM
shyguy4no1
Feb 12, 2010 12:42 PM
mr_hahn73
Nov 11, 2005 05:58 PM
Bond
24
Apr 1, 2005 12:08 PM
Dent Free
Nov 16, 2004 02:45 PM
