Honda CR-V & Element 2WD & 4WD Element & CR-V
09 CRV A/C weird problem, please help!
Old Aug 11, 2012 | 06:54 PM
05foresterxt's Avatar
Default 09 CRV A/C weird problem, please help!
My friend's Dad has an 09 CRV with about 90k miles.
While waiting at a drive-through here in San Diego, he noticed steam coming out both sides of the car. He assumed that this was an issue with his cooling system, but the temp gauge never changed.
He then noticed that the A/C, although cold, was slowing down. So the fan was blowing but it started to slow down. Now the car's A/C is only blowing warm air and has no idea what happened.
Has anyone ever had this issue? If so, what could be the problem/solution? What, if any, could we check to verify such?
I've been working on cars for many years and I've never heard of such a problem.
Thanks.
Old Aug 11, 2012 | 08:51 PM
Default Re: 09 CRV A/C weird problem, please help!
He also described his battery draining to the point that they had to replace it.
Old Aug 11, 2012 | 09:07 PM
Qfactor's Avatar
a/c clutch relay stuck in closed position, is in the fuse box in the engine compartment which is labeled with a snow flake, replace it. have the a/c system serviced since it lost refrigerant thru the pressure relief valve. this will drain the battery since the a/c coil is energized when the engine is off. and for the smoke/steam he saw is the refrigerant coming out of the press. relief valve due to high pressure in the system.
Old Aug 11, 2012 | 09:29 PM
arrasmithf's Avatar
I read somewhere else(not honda specific forum), that if the pressure relief valve blows open, you may have to replace it. is this true for '09 CR-V?
MCHAccordLX
Honda Civic (2001 - 2005)
May 5, 2015 09:22 AM
DCkid
Feb 13, 2010 06:46 PM
LHC
Jan 30, 2004 06:37 PM
blackhatch1380
Jul 21, 2003 09:46 AM
