95 Civic - engine and cluster gauges shut off at 80mph on the freeway
Old Aug 11, 2012 | 03:04 AM
haxing's Avatar
Default 95 Civic - engine and cluster gauges shut off at 80mph on the freeway
hi i need help on my problem. I was going around 80mph on the freeway and my car just shuts off on me..gauges turn off and everything but still, my car is coasting and slowly de-accelerating then my car fires back up.. then my guages rises to its current speed... and everything is back to normal. it has happend a couple of times before but not that many time..
I wonder why its doing that? i know very little about cars so can anyone care to explain why this is happening?
ive also check my spark plug wells, the 2 tubes in the middle seems to have oil going in it. not much but slowly building.. ive replaced the seal about a month ago and it seems to be filling up again *barely tho this time*.. is that the cause of it? any ideas?
Old Aug 11, 2012 | 06:38 AM
Former User's Avatar
Default Re: 95 Civic - engine and cluster gauges shut off at 80mph on the freeway
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
-Test the ignition switch.
-Clean and tighten the battery connectors and the ground wire attached to the chassis.
Old Aug 11, 2012 | 08:29 AM
92lxsleeper's Avatar
+1000000000000 on ignition switch.
Chilloutdamn
Mar 9, 2013 11:50 AM
civics4lyfe
Apr 13, 2010 11:33 AM
SHO-NUFF
Jun 22, 2009 10:27 PM
suprmods
11
Jan 24, 2006 09:20 AM
Buddy10297
Sep 29, 2005 07:38 PM
