low fuel light doesnt come on
Old Aug 9, 2012 | 02:02 PM
Civic Racer X 7's Avatar
Default low fuel light doesnt come on
I know its a petty thing to be concerned with but I have been running real low trying to see if the light will come on and its got to be where it should have come on by now
I took the cluster out and swapped the seat belt light with it and its still not on
If the bulb is good what else would cause this?
the gauge itself operates correctly
Old Aug 9, 2012 | 02:21 PM
Former User's Avatar
Default Re: low fuel light doesnt come on
What car?
Old Aug 9, 2012 | 02:34 PM
oops sorry 2000 civic ex
Old Aug 9, 2012 | 02:51 PM
tunerboy254's Avatar
lol ronj is always on top of it
im interested too, my light never comes on
oh and for the ronj 98 civic coupe hx lol
Old Aug 9, 2012 | 03:55 PM
Both cars:
Remove rear seat and cover to the fuel pump. Unplug the 3P connector for the sending unit, which has Grn/Yel, Blk, and Yel/Blk wires. Use a paperclip or wire to jump the Grn/Yel wire terminal to the Blk wire wire terminal in the connector.
When you turn the key to ON(II), does the cluster low fuel indicator light turn on?
Old Aug 11, 2012 | 07:56 AM
Ron i did as you instructed the light did come on. I also noticed a white goo in the connections
Looked to have been applied deliberatly.
Old Aug 11, 2012 | 08:21 AM
92lxsleeper's Avatar
that would be dielectric grease, used to prevent corosion. last owner probably put a little too much.
Old Aug 11, 2012 | 08:27 AM
As mentioned, ignore the goo. It's fine.
If you have run the fuel tank to less than 1 gallon of being empty and the light has not turned on, then replace the fuel sending unit in the fuel tank.
Old Aug 11, 2012 | 11:34 AM
do I need a 99-00 civic fuel sending unit?
or will anyone from a 96-00 work?
does the trim matter?
http://www.ebay.com/itm/96-00-Honda-...r#ht_500wt_969
HondaScene
Feb 7, 2012 08:30 AM
ekblackcoupe
May 27, 2011 12:37 PM
SoullessJapaneseMachine
12
Dec 8, 2007 05:47 PM
b20vtech
Aug 29, 2006 08:48 AM
Got2HaveSol
Aug 28, 2005 03:59 PM
