starting problem on 90 hatch.
When I go to start the car it turns over, but as soon as I let go of the key it turns off. If I hold the key in the "start" position the car will run.. But as soon as I let the key go and it returns to the "on" position the engine cuts out.
What's the deal??
I replaced my starter last year and when I did that it only had one bolt holding it in place.. So I just replaced it the same way I found it.. Could my starter just be loose? Or is it something with the ignition? thanks!
What's the deal??
Almost sounds like a bad ignition switch.........and go to the junk yard and get yourself the other starter bolt. Hell, you could do a five finger discount for the damn bolt.
What's the deal??
What's the deal??
When you release the ignition switch from ON(III) to ON(II) and the engine stalls, do the cluster warning lights remain on or are they off. If they are off, replace the ignition switch.
runitup
21
Dec 26, 2020 05:17 PM
gRim06
13
Oct 18, 2007 10:14 PM
Elite Hatch
Nov 24, 2002 10:06 PM
