Binding Issues
Old Aug 8, 2012 | 09:14 PM
ef_dx_90's Avatar
Default Binding Issues
Car is a 1990 Civic hatch DX. I am having a binding issue on the driver's side.
Currently swapped a B18C with a ys1(gsr) tranny. The intermediate shaft is off a '90 DA. I first used the '90 DA axles, but wasn't enough clearance. Then saw that crx_si-r was using axles off an '89 DA for clearance, so I picked some up and was binding less. But I am still having the same issue.
Any ideas? Thanks in advance
Old Aug 9, 2012 | 06:16 AM
crxin's Avatar
Default Re: Binding Issues
try 93 integra axles
Old Aug 9, 2012 | 06:43 AM
4drEF's Avatar
Keyboard Humorist
binding where?
removed dust guard off inner side of wheel bearing?
Old Aug 9, 2012 | 08:02 AM
90civic-ZC's Avatar
Exactly what i was gonna ask, check for the dust guard ring.
Old Aug 9, 2012 | 11:06 AM
zrickety's Avatar
Remove the dust rings on the knuckles. If that's not it, do you have reputable engine mounts?
Old Aug 9, 2012 | 01:12 PM
ef_dx_90's Avatar
Binding is coming from the driver's side wheel.
I removed the dust ring on the inner side of the wheel bearing and helped a whole lot more. I can actually drive the car now, but still makes the noise when I accelerate and deccelarate, or hit a bump.
Mounts are Innovative. Steel mounts with red inserts.
Old Aug 9, 2012 | 02:21 PM
MRZCCRX's Avatar
Is the axle locked into the half-shaft ?? could be just a lil out and causing your problem
Old Aug 9, 2012 | 02:36 PM
4drEF's Avatar
Keyboard Humorist
That's good news!
Is your car lowered? How much?
88/89 axles are shorter than the DA.
Some people that have lowered a lot run into binding as the axles are put at a straighter angle than at stock height.
Using the 88/89 fixes the binding.
Old Aug 9, 2012 | 03:12 PM
ef_dx_90's Avatar
Originally Posted by 4drEF
That's good news!
Car is lowered. Was tucking a tad bit of the tire, then I raised it to a complete finger gap and helped more.
And yes axle is locked into the halfshaft.
Old Aug 9, 2012 | 05:22 PM
zrickety's Avatar
Are you sure the noise isn't the shield on the brake rotor?
Old Aug 9, 2012 | 07:57 PM
ef_dx_90's Avatar
I don't think it could be that because I feel it on the steering wheel.
Old Aug 9, 2012 | 09:34 PM
Super79Dave's Avatar
check your intermediate shaft. i believe you need the sh3 shaft.
Posted from Honda-tech.com App for Android
Old Aug 9, 2012 | 09:55 PM
lsvda's Avatar
have u checked ur axle nut
Old Aug 10, 2012 | 06:43 AM
zrickety's Avatar
No offense Super Dave, but the SH3 is longer and will make the situation worse. The 90 DA intermediate shaft is correct, should say SK7.
Old Aug 10, 2012 | 07:35 PM
ef_dx_90's Avatar
Correct. Reads SK7. SH3 is off the SI-R which is longer. Axle nut is secure.
Don't really know what else to do.
Old Aug 10, 2012 | 08:54 PM
4drEF's Avatar
Keyboard Humorist
Raise your car up and see if it goes away.
If it does, then a different mount kit that is more friendly with lowered cars or shorter axles is all I can suggest.
Old Aug 11, 2012 | 04:51 AM
zrickety's Avatar
Your binding may be gone. If it makes noise when you hit a bump, and you feel something in the wheel, it could be tie rods, inner or outer, or a ball joint. Are you running a traction bar?
Old Aug 11, 2012 | 11:21 PM
ef_dx_90's Avatar
That's what i was thinking.
You think Hasport mount kit would make it sit higher?
I was already having problem with clearance with the hood. I think I might need washers on the hindges just for clearance.
Old Aug 11, 2012 | 11:23 PM
ef_dx_90's Avatar
Just last week with my D15B2 wasn't like that, but maybe because its holding more weight up front?
And no, no traction bar.
Old Aug 13, 2012 | 10:09 PM
ef_dx_90's Avatar
Could it be that they just gave me a defective axle?
Old Aug 16, 2012 | 11:30 AM
ef_dx_90's Avatar
Has anybody heard or tried shortening an axle?
Old Aug 19, 2012 | 10:58 AM
ef_dx_90's Avatar
Anybody??
Old Aug 20, 2012 | 03:19 PM
ef_dx_90's Avatar
Ttt
mafia
May 7, 2012 12:06 PM
stealth_EK4
Suspension & Brakes
Aug 21, 2005 09:35 PM
El_Capitan
25
Jul 18, 2005 04:09 PM
SpOoNisMyFriEnD
Apr 5, 2005 05:19 PM
servion
Jul 7, 2003 07:06 AM
