stopped burning oil??????
Old Oct 15, 2002 | 07:58 PM
lsteggy's Avatar
Default stopped burning oil??????
ok when i first got my car it burnt about a quart of oil every 3000 miles. it had 107k when i bought it. At 116k, right before school started i did a little tune up. i got a skunk 2 intake manifold, im gasket, oil change, sparkplugs, and fpr. i cleaned everything up with carb cleaner: injectors, throttle body, and intake ports. since doing that i havent burnt any oil. its been 2300 miles and my oil is golden brown and up the the second dot. it now has 118k i was just wondering what could have happened so that i stopped burning oil?
Old Oct 15, 2002 | 11:25 PM
TimoneX's Avatar
New User
Default Re: stopped burning oil?????? (lsteggy)
Sure it wasn't leaking?
Old Oct 16, 2002 | 05:46 PM
lsteggy's Avatar
Default Re: stopped burning oil?????? (TimoneX)
yea man im pretty sure. the oil would always turn black isnt that i sign it was burning?
Old Oct 16, 2002 | 05:48 PM
The_Oz's Avatar
Ummm....no.
Oz
Old Oct 16, 2002 | 05:57 PM
lsteggy's Avatar
Default Re: stopped burning oil?????? (The_Oz)
there wasnt any oil on my garage floor
Old Oct 16, 2002 | 06:06 PM
The_Oz's Avatar
What I am trying to say is there is no direct correlation between the colour of the oil when you have a burning issue (not talking about what comes out of the exhaust pipe, btw). So, no, just because it's black doesn't mean it's burning oil.
Regards,
Oz
[Modified by The_Oz, 10:06 PM 10/16/2002]
Old Oct 16, 2002 | 06:11 PM
lsteggy's Avatar
Regards,
Oz
yea man i got ya
Old Oct 16, 2002 | 06:22 PM
TimoneX's Avatar
New User
Actually, it usually does turn black if you have piston ring blow by. Mine turns black within a day or two. Why/how your problem was fixed with what you did I don't know though.
Old Oct 16, 2002 | 06:24 PM
TimoneX's Avatar
New User
Have you done a compression test on your engine by chance?
Old Oct 16, 2002 | 06:30 PM
ragejed's Avatar
weird, my oil is black every time i drain it.....only 45k here
samagon's Avatar
actually, oil turns black regardless of what is going on with your engine. it can be two days off of the ship from japan and after a few days driving the oil will be black.
Old Oct 16, 2002 | 07:08 PM
TimoneX's Avatar
New User
Default Re: stopped burning oil?????? (samagon)
Of course oil turns black every time you change it. I think we'd all agree it shouldn't be a cloudy black after less than 300 miles of typical driving though. Mine is and what do you know I have a compression loss caused by worn piston rings. This does not typically occur with healthy piston rings.
Old Oct 16, 2002 | 07:52 PM
vtec.dc2's Avatar
what pressure do you run your fpr at?
Old Oct 17, 2002 | 10:10 AM
The_Oz's Avatar
Different oils react differently...I would put my bet on that before thinking I have major blow-by. If that was the case then I shouldn't be using Mobil Delvac 1 when it turned black within 1000km of driving compared to WalMart Tech2000 which wasn't even black after 5000km.
Regards,
Oz
Old Oct 17, 2002 | 11:41 AM
TimoneX's Avatar
New User
You put your bet on whatever you like, but when you're watching smoke roll off your exhaust on acceleration, losing oil quickly, and watch ANY brand/weight of oil you put in your engine turn black within a few hundred miles, I think you'll find you have worn rings.
Old Oct 17, 2002 | 12:36 PM
mickey513's Avatar
You might want to run some of these high mileage oil like Valvoline Maxlife or Pennzoil High Mileage. They have seal conditioners in them that can help reduce leaks and seal seals....
Old Oct 18, 2002 | 10:14 AM
TimoneX's Avatar
New User
Default Re: stopped burning oil?????? (mickey513)
Been there done that. Makes 0 difference. Matter fact Max Life 10-40 is in there now. The only thing that's going to change this situation is new rings.
Old Oct 18, 2002 | 12:00 PM
Rtzx9r's Avatar
GDD 1%
Oil turns black because it collects dirt/carbon in your engine- it "hangs" in the oil. It is normal, and happens on all cars, regardles sof milage.
Old Oct 18, 2002 | 12:09 PM
TimoneX's Avatar
New User
Default Re: stopped burning oil?????? (Rtzx9r)
So you contend that the presence of blow-by has no effect whatsoever on oil color? That the fact that my oil turns black almost immediately now whereas it didn't before I started losing compression is just a coincidence? There's mountains of evidence stacked up against you.
highwhey
Nov 11, 2010 05:53 AM
Wish2345
26
Mar 23, 2010 01:47 AM
d_mart
26
Jul 8, 2005 06:56 AM
digitalayon
Mar 13, 2005 07:55 AM
oMek
Mar 2, 2004 07:25 PM
