misshift now high idle when car is warmes up help??
Old Aug 8, 2012 | 09:53 AM
b20bFourDoorCivicLX's Avatar
Default misshift now high idle when car is warmes up help??
I reset my computer. loosened. throttle cable still idles at 1500 after driving. doesn't do it at 1st start of the day only when cars hot. what did I do? do I need a new idle xonrrol vavle or a vavle adjustmnthelp me out
Old Aug 8, 2012 | 05:11 PM
TheRealTegger's Avatar
Default Re: misshift now high idle when car is warmes up help??
Throttle cable idles at 1500rpm? That's a new one on me.
It's amazing how moronic one appears when using a cell phone to post one's messages.
Try a new, more coherent post, and this time NOT from a CELL PHONE!
Old Aug 8, 2012 | 09:58 PM
el crapitan's Avatar
with the vehicle warmed up, pull the intake boot off. feel for suction at the fitv port on the throttlebody. should be the lower port of the two, if i'm not mistaken. if you cover the fitv port with your finger and the idle drops, problem is stuck open fitv. if idle doesn't drop, cover the iac port. if idle does not drop, air is entering through a leak somewhere.
if idle does drop, disconnect the iac and try adjusting idle
also, make sure that the coolant level isn't low, and that the vehicle does actually get to operating temp
Arthas
Mar 14, 2010 09:08 PM
sik_sol
Aug 18, 2006 02:08 PM
PINKS
May 29, 2006 10:26 PM
chirp2hrd
Oct 13, 2002 01:36 AM
350z-tech
Nov 10, 2001 10:46 PM
