Is this normal???
Old Aug 7, 2012 | 01:11 PM
Darklord's Avatar
Default Is this normal???
I bought this set of new cams and saw this, is this normal or this is from a bad casting?
Thanks for the help
Old Aug 7, 2012 | 01:28 PM
slowcivic2k's Avatar
Default Re: Is this normal???
The casting looks okay to me, however it does look a bit strange doesn't it? As long as the edges do not land in a journal or the rocker pads touch them there would be no problem with what I see.
Old Aug 8, 2012 | 04:05 AM
Darklord's Avatar
It's strange for sure, i've already installed many other cams (from other brands) and i've never seen something like that...
Old Aug 8, 2012 | 09:23 AM
doood's Avatar
been there done that
what cams are these?
Old Aug 8, 2012 | 10:44 AM
scmil95eg's Avatar
core shift. it's fairly common with cast cams to a degree (or any cast part for that matter). As long as there isn't interference, the rocker pads won't know the difference.
Old Aug 8, 2012 | 11:50 AM
Darklord's Avatar
If is common on cast cams why i never saw a oem cam like this? For me this was a cam that doesn't had the final inspection control and some how pass, maybe some distraction or whatever from the operator. On this set only the exhaust one came like this the intake one is perfect.
Old Aug 8, 2012 | 12:26 PM
scmil95eg's Avatar
Because you obviously haven't seen enough OEM cams. The OEM K20A3 cams currently sitting on my desk are exactly the same - Honda doesn't even grind off the parting line flash!!!! Every K-series cam from Honda must be defective from the factory!!! Revolt!!!!
In all seriousness, cast cams hardly ever look like they jewels they shoot for product and promotional photos.
The issue you've brought to everyone's attention is no cause for concern. But don't take my word for it, I only see a couple hundred sets of cams per month.
Old Aug 8, 2012 | 01:04 PM
Darklord's Avatar
This is a B series cam and i'm talking about them not K series. And yes K series i did not see enought cams only about 20 sets.
Anyway i thank's for your reply and take it easy kid don't revolt too much.
Can you share with us a couple of pictures of the camshaft that you have on your desk?
Old Aug 8, 2012 | 01:09 PM
scmil95eg's Avatar
I was one step ahead of ya until I realized the camera battery is dead. It's charging now, I'll post some pics up tomorrow. The exhaust cam on my desk is particularly nice since it has core shift at the peak of the #1 lobe. And it was run for 160,000+ miles without issue.
Old Aug 8, 2012 | 01:22 PM
Darklord's Avatar
What i think is strange on this particular cam is that all the lobes on both sides has this problem and the intake one is perfect like i said before.
One of the lobes even doesn't look straight.
Ok then when the battery is full just share the pic. I will take some more pics too of this camshaft.
Thanks
Old Aug 9, 2012 | 05:42 AM
scmil95eg's Avatar
Old Aug 9, 2012 | 02:16 PM
Darklord's Avatar
Look's very bad too
The maker of the cam in my picture claim that they use cnc machine how can a cnc machine leave a finish like this?
Old Aug 9, 2012 | 03:26 PM
doood's Avatar
Old Aug 10, 2012 | 04:03 AM
Darklord's Avatar
I'm not saying the brand of the cams since i don't want to damage the brand in anyway. Currently, they have been helping me out with some issues, therefor i'll fill you out on the cams if that doesn't work out.
Thanks for understanding
Old Aug 11, 2012 | 12:28 PM
Darklord's Avatar
Some more pics:
Fang7054
Jan 8, 2012 02:58 PM
jdm ek9 101
Sep 13, 2006 04:46 PM
itr1244
10
Jun 13, 2006 10:05 AM
pierrot le fou
Sep 6, 2003 08:57 AM
