timing belt changed, now its knocking
As titled I changed the timing belt and installed a new water pump in a 96 accord non vtec . and upon its first drive I noticed it seemed to rev faster and didn't have the same feel of power. And at an idle there's a knock or ticking that sounds like its the valves. I marked all the pullys and gears as to re align everything as if it hadn't moved. could I be a tooth or two off on the can pully? could really use the help fellas. thanks Andy
kaoss_11
Aug 9, 2005 01:55 PM
