Car won't start after shooting nos
Old Aug 5, 2012 | 06:54 PM
Egpower88's Avatar
Default Car won't start after shooting nos
Ok long story so I'm just gonna cut it down a little.. My car shut off while I was testing out my 55 shot of nos and there was a big back fire.. So got it home and did some test, I wasn't getting no sparks so I use my buddy dizzy and now im getting spark.. Every time I crank it over and when it's about to start white smoke kicks out from my intake manifold.. The cranking sound normal..
What I done so far
1. Compression test is good
2. Getting gas and main replay click
3. Check all fuse
4. Check spark plugs and they were fine
5. Timing is good
I would really appreciate if I can get some tips on what to check next.. Thanks
Old Aug 5, 2012 | 07:18 PM
Kr4nG's Avatar
Default Re: Car won't start after shooting nos
maybe you bent some rods so your timing is off. pull the spark plugs and see if your piston is coming all the way up where it should be. or pull the oil pan and check the actual rods.
Old Aug 6, 2012 | 05:36 AM
fcm's Avatar
fcm
Old Fart
You said timing is correct, did you check valve timing? 94
Old Aug 7, 2012 | 04:37 AM
Egpower88's Avatar
I check the crank pulley top dead center and it line up with the cams gears..
Old Aug 7, 2012 | 05:16 AM
fcm's Avatar
fcm
Old Fart
Are you getting fuel into the cylinders, are the injectors "firing"?94
Old Aug 7, 2012 | 05:26 AM
Egpower88's Avatar
Are you getting fuel into the cylinders, ar the injectors "firing"?94
Good one ill try that out later..
Old Aug 7, 2012 | 05:28 AM
Egpower88's Avatar
94?? If your wondering if its an 94 it is..
Old Aug 7, 2012 | 05:48 AM
fcm's Avatar
fcm
Old Fart
I was not, the 94 is the way I end all my posts, it is what I own, [94 Acura Integra RS] it is my autocross racing number along with other personal significance, besides it just works better then 10/4. 94
Old Aug 7, 2012 | 05:56 AM
cdaiscool's Avatar
He signs all his posts as 94.
I x2 on something messed up internally. Pull the plugs, check out if all the pistons look good. If it went bang when you hit the button, it very well may have ****ered up a piston. Built or stock internals?
Edit: He beat me to it.
Old Aug 7, 2012 | 06:03 AM
Egpower88's Avatar
It actually back fire and shut off on me.. Stock internal.. If I have a bad piston wouldn't I be losing compression?
Old Aug 7, 2012 | 06:04 AM
Egpower88's Avatar
While it was spraying ^
Old Aug 7, 2012 | 11:19 AM
fcm's Avatar
fcm
Old Fart
A backfire would indicate a timing issue, are you absolutely sure valve timing is correct? 94
Old Aug 7, 2012 | 11:23 AM
Dc4LsTeG's Avatar
EK9
Yea I'd recheck your mechanical timing
Old Aug 7, 2012 | 03:39 PM
JuicedUpRice's Avatar
timing...either valve timing,mechanical timing,or a bent rod which in turn would F the timing hard..
what exactly were your compression results?list them.
Old Aug 8, 2012 | 05:43 AM
fcm's Avatar
fcm
Old Fart
Have you checked for fuel in the cylinders yet?
Simple test, try starting the engine a few times, then immediately remove a spark plug and inspect the end, is it "wet" with gas, does it smell of gas, can you light it up, if you put a match/lighter to it? 94
90Rexx
Jul 3, 2009 06:23 AM
KingJeff
May 2, 2007 03:20 PM
CodyC142
Nov 1, 2006 07:08 AM
mygfs92lx
Jul 19, 2006 06:33 PM
xteg95
Jun 18, 2003 09:50 PM
