Hot real HOT
Check to make sure that your thermostat is opening (you have to take it out to do this, so just replace it). Also check to make sure that your cooling system has been bled properly. To bleed your cooling system start the engine, turn the heater full on, and unscrew the little nipple on the passenger's side of the head, wait for coolant to come out in a steady stream, then close the nipple by screwing it back in. If it is neither of these things, check for a blocked radiator or cooling fans that do not come on.
jeremyrocksursox
Aug 27, 2009 07:29 PM
