Another Carbon fiber hood issue.
Old Aug 5, 2012 | 04:00 AM
skaraider's Avatar
Default Another Carbon fiber hood issue.
Well i bolted the hood up last night it fits well, the only issue I am having is that the hood won't latch onto the OEM hood latch in the front of the hood. It hits it where it suppose to but it doesn't shut, i lubricated the springs and latch itself and still no luck. I don't want to drop the hood or press down because i don't want to break it. I can't afford hood pins yet.
Ill post a picture later tonight when i get home from work. any help till now would be great.
Old Aug 5, 2012 | 04:03 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Another Carbon fiber hood issue.
You couldn't break it if you tried. It isn't fragile.
But chances are with the fitment issues you're having that if you DO get it to latch you won't get it to unlatch.
What brand is the hood?
Old Aug 5, 2012 | 04:24 AM
skaraider's Avatar
NRG innovation
Old Aug 5, 2012 | 06:27 AM
MRGRIM's Avatar
R.I.P. Mark
adjust the hood rubbers near the headlights on the radiator support panel
you can turn them to raise or lower
Old Aug 5, 2012 | 06:44 AM
skaraider's Avatar
yeah, i didn't think about that it was 11pm when i was doing this so i just stoped to get some sleep. When i get home from work ill check on that.
Old Aug 5, 2012 | 08:13 AM
gsrturbo-ek's Avatar
adjust rubber bump stops also the latch cant be adjusted also
Old Aug 5, 2012 | 08:34 AM
integra_101's Avatar
if u ran over your hood wit a car, it still wouldnt break. ive done it lol
Old Aug 5, 2012 | 08:39 AM
The Grumpiest
Never had an issue installing a hood. It was remove the old one and replace with new. The only time I ever see someone have issues like this is if the radiator support was damaged in an accident.
Old Aug 5, 2012 | 08:41 AM
hondata760's Avatar
yeah but if it comes open goin 50 and slams into your windshield it will! I've done it lol
Old Aug 5, 2012 | 08:53 AM
skaraider's Avatar
yeah, im guessing it will be the rubber pieces, 4 hours till i get home and ill update you guy.
Old Aug 5, 2012 | 12:00 PM
ozh_hawaiian's Avatar
been there done that!!! which is why I have a carbon hood now! lol
I had small issues when I put my carbon hood on, but I think it was because I put a coupe hood on my eg8 sedan... but I had to sand down the hook that cathes on the hood because it was hitting... also you sould think about notching the latch on the hood itself so you can adjust it to catch properly
Old Aug 5, 2012 | 03:05 PM
skaraider's Avatar
yeah so i removed the rubber things and radiator stay bracket and its still not closing. I even adjusted the part the hood connect to car it has a small adjustment where it raises and lowers. so i raised it as much as it would go, not even a 1/4 inch and it still didnt work..
now when you say NOTCH do you mean take it from a square form to maybe what U shape?
Old Aug 5, 2012 | 03:58 PM
the part that is on the hood is square, and has four bolt holes... notch the holes a little so you can move that piece either forward or backwards(towards the front of the car or towards the firewall), this might give you the adjustment you need to get it to fit...
I had tho sand this down, because it was too tall, and was not allowing my hood to latch correctly
Old Aug 5, 2012 | 06:47 PM
Tkrizz's Avatar
I've had this problem with my cf hood for a while now. It doesnt close right sometimes and i have to move the latch on the hood left or right (towards the fenders) to get it to close. I figured out if i mess with that enough and get it to the right spot i just go pull the hood latch again and then it will close almost every time. Hope this helps.
Old Aug 6, 2012 | 02:56 AM
skaraider's Avatar
yeah I finally got it, but i have to press firmly down on it. Thanks,
Old Aug 6, 2012 | 09:47 AM
dpetro1's Avatar
as long as you push down firmly, directly over the latch, you wont have a problem. obviously you dont want to let the hood slam down like a metal hood. its isnt heavy enough to close on its own and you risk damage.
get hood pins ASAP. i wouldnt trust a fiberglassed latch on its own
Old Aug 6, 2012 | 09:51 AM
Echelon's Avatar
I had this issue a long time ago when I had a Seibon CF hood on my EG. Hopefully it doesn't get too cold where you are becaues it will be even harder to close in the winter.
integraty95
Apr 21, 2009 01:18 AM
aquito
Dec 29, 2007 11:58 PM
hondacrx2
Oct 12, 2007 10:16 AM
99turboedsi
Jul 12, 2006 03:28 PM
StolenTeg
Aug 23, 2004 09:50 PM
