LS/VTEC or Turbo LS?
Old Oct 15, 2002 | 06:03 PM
mr_mbuna's Avatar
Default LS/VTEC or Turbo LS?
Hey guys,
I have an LS Integra with 140,000 miles. I've been reading about how to do LS/VTEC (seems easy), but I've also read that LS/VTEC is unreliable.
My question is, what is more cost-effective and reliable? LS/VTEC or Turbo? I want to get about 200 whp on my Integra. I've been told that I can get there with low boost, about 7 psi. What is the hp gain on a mild LS/VTEC conversion?
Thanks,
Ben
Old Oct 15, 2002 | 06:19 PM
94teggyls's Avatar
Default Re: LS/VTEC or Turbo LS? (mr_mbuna)
with a nice ls vtec setup u can get from 170 hp to 200 but i would go turbo better results and more realible but do a search this was covered at leasr 20 times
Old Oct 15, 2002 | 06:21 PM
mr_mbuna's Avatar
Default Re: LS/VTEC or Turbo LS? (94teggyls)
I didn't find any reliability comparison posts... mostly howto posts. I did try.
Ben
Old Oct 15, 2002 | 07:49 PM
B00ST2nR's Avatar
LS/Vtec Turbo!
Old Oct 15, 2002 | 08:02 PM
Audi A4's Avatar
Default Re: LS/VTEC or Turbo LS? (Skunk2nR)
ls/vtec is a more relaible set up. boost plays to many factors. and if u get ls/vtec done the right way, then it a awesome st up.
Old Oct 15, 2002 | 11:41 PM
Ri5e's Avatar
Default Re: LS/VTEC or Turbo LS? (DRAG lll INTEGRA)
Do turbo. LS Turbo @ 7 psi should make more power then a LS/VTEC.
Old Oct 16, 2002 | 12:26 AM
SIK IN DA HED's Avatar
New User
Default Re: LS/VTEC or Turbo LS? (4 Stroke)
turbo LS LSVtec aint **** unless u build the motor. if youre gonna do that.. you might as well build the LS for more boost.
Old Oct 16, 2002 | 05:10 AM
The Rob's Avatar
Default Re: LS/VTEC or Turbo LS? (dlplayboy)
LS Turbo. I have seen this same post like 20 times this week on here.
Old Oct 16, 2002 | 05:32 AM
au-gsr's Avatar
go turbo save some money for the rest of the car. besides you'll get better power gains out of it. more bang for the buck. just maintain the car a lil more meticulously and it should be jsut fine.
Old Oct 16, 2002 | 05:33 AM
Charlie Moua's Avatar
haha very true.
Old Oct 16, 2002 | 06:11 AM
TurbothisLS's Avatar
Default Re: LS/VTEC or Turbo LS? (Charlie)
yes, turbo LS...just completed mine
Old Oct 16, 2002 | 10:20 AM
B18Redline's Avatar
yeah, you will get 200 HP quicker w/a turbo.
your car has a lot of miles though, but if you had the car for the majority of it's life and have maintained it, then it should be fine to boost.....and if you did end up having motor problems, big deal, your engine had a lot of miles on it anyway.
If you do decide to go turbo, build up bottom end. don't run on stock internals.
Old Oct 16, 2002 | 12:28 PM
JLange's Avatar
Default Re: LS/VTEC or Turbo LS? (Redline07)
turbo
r1ch
Jan 24, 2007 06:44 AM
crixer340
Aug 14, 2006 04:01 PM
KMk51188
Jul 26, 2006 04:20 PM
ekVtecPower
12
Jun 24, 2006 04:34 AM
lscoupe
Mar 13, 2005 07:56 AM
