what should i do to a transmission before installing
Old Aug 3, 2012 | 09:20 PM
GPC91's Avatar
Default what should i do to a transmission before installing
ok so i have an si trans that i have been keeping around because the sincros in 2 3 4 and 5 have been acting up and a bent shift fork in 3rd. old tranny (200 plus i believe) and i helped a few friends learn a 5 speed so it got pretty beat. but anyways the time has come to replace it. i already have my old trans out and i was just curious what i should do to my new trans before i put it in. i know for a fact that it ran amazing 3 years ago when pulled and it has had rags in the holes so nothing got in. but im just curious what should i do if anything before installing. like do axle seals go bad from drying out? and when its in should i change tranny fluid maybe a few hundred miles later just to make sure if anything was in it that its out? just trying not to have to drop the tanny again. its a bitch to do and i dropped in on my chest today when my hand slipped.
thanks for the help guys
Old Aug 4, 2012 | 11:18 AM
EF8Celeste's Avatar
Default Re: what should i do to a transmission before installing
check for bad seals and bearings. and look for cracks or exessive wear. it would suck to get a trans in and then have a leak.
TheCrimsonGhost666
Transmission & Drivetrain
May 9, 2011 09:03 PM
litoekneeil
Jun 8, 2010 08:53 AM
slitterman
Feb 21, 2010 11:54 AM
citrus3000psi
Dec 26, 2007 07:29 PM
xteg95
Nov 22, 2003 08:10 PM
