Best Turbo Choice for B20Z
Old Aug 3, 2012 | 10:32 AM
nothing_shocking's Avatar
Default Best Turbo Choice for B20Z
Stock engine. I'm trying to decide between a 14B and a small 16G Mitsu turbo. I'd more than likely run 7 psi on the 16g and 9 on the 14b. My goal is to get supercharger style boost out of a turbo, but I'm not sure which turbo would be better for that. I'm not worried about HP goals, I'm more interested in instant torque, although, since I have a stock engine, I have to take the HP into account.
Any advice?
Old Aug 3, 2012 | 10:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: Best Turbo Choice for B20Z
If you want instant boost then smaller is always better.
Old Aug 3, 2012 | 12:42 PM
eg6-jarhead's Avatar
dont want to run out of breath though ^
i wouldnt go smaller than a 18g on a 2.0L for what you want
but personnally a 3582r garrett is what i would run on a 1.8L but im a straight line freak lol
Old Aug 3, 2012 | 02:05 PM
Julio@Bisimoto's Avatar
With a 2.0L such as your B20 I would suggest going to a larger sized turbo than the two you had mentioned, being it will choke out very quickly at higher rpms. Have you looked into a properly sized T3/T4 turbo? You can still have a very responsive setup as well high horse power capability for future modifications later down the road.
I have had great success with a Turbonetics 5757 journal bearing turbo on stock internal engines such as yours and even smaller engines such as D16's with very fast spool times. Not to mention they are cost effective and have a 1 year warranty. Check it out on this link: Turbonetics T3/T4 57mm turbo
Old Aug 3, 2012 | 02:31 PM
nealnanoHX's Avatar
Both the 16g and 14g are too small for a B series motor. If you what a responsive turbo that will not run of of breath in the higher rpms but still do up to 300whp get a Garrett Super 60.
What kind of spool times are we looking at though? Roughly at what RPM would I be hitting full boost for any of them?
Old Aug 3, 2012 | 02:45 PM
nealnanoHX's Avatar
The Super 60 will see peak boot at around 2000-2500 rpms. A T3T4 will be a little later around 3000-3500.
Old Aug 3, 2012 | 03:35 PM
2k RPM for peak boost would be great, but I'm really looking to stay with Mitsubishi turbo's. The current pieces I have are all for a Mitsu turbo and I'm not wanting to redo my entire kit.
thalwr1
Feb 2, 2009 12:54 PM
driveahonda
Nov 17, 2006 07:17 AM
XES
Oct 19, 2005 05:50 PM
TurboMiata
May 15, 2005 04:41 AM
b18c1wes
Apr 5, 2005 06:29 PM
