R-134a
Old Aug 3, 2012 | 09:49 AM
Kenny88880's Avatar
Icon6 R-134a
What is the minimum amount of r-134a needed for the compressor to kick on? I have 0.93lbs (14.88oz), or one can in my system as of now. Compressor is not kicking on after condensor replacement. It worked before :/...what gives?
Car is a 1996 del Sol VTEC.
Old Aug 3, 2012 | 11:07 AM
MonkeyMagic's Avatar
Default Re: R-134a
compressor will kick on even if there are no lines attached. it's probably not plugged in.
you did vacuum the system didn't you?
Old Aug 3, 2012 | 11:20 AM
Kenny88880's Avatar
Default Re: R-134a
Yeah, it was evacuated and vacuumed with a professional machine.
Old Aug 3, 2012 | 11:21 AM
Kenny88880's Avatar
Default Re: R-134a
Where does it plug in?
Old Aug 3, 2012 | 11:27 AM
Default Re: R-134a
should have one red wire coming off the pulley side of the compressor and plugs in right by the condensor fan's plug.
Old Aug 3, 2012 | 01:47 PM
Kenny88880's Avatar
Default Re: R-134a
can I put 12v on that red wire? It was plugged in...
Old Aug 3, 2012 | 02:20 PM
Kenny88880's Avatar
Default Re: R-134a
I put 12v on the BLACK wire coming from the compressor. It runs into a red wire on the other side of the plug. There are two coming from my compressor, one is a ground, but they are both black. Where is the low pressure switch, and what is the procedure for jumping it?
Old Aug 3, 2012 | 02:21 PM
Default Re: R-134a
see if it has 12v with engine on, hvac fan on, and a/c switch on.
Old Aug 3, 2012 | 02:29 PM
Kenny88880's Avatar
Default Re: R-134a
Well I just tested that and got nothing. The fan did not come on either...
kf6rcp
Jul 11, 2013 10:38 AM
ivan93egreppin210
Jun 19, 2010 02:15 PM
hard_boiled_EG
Jul 2, 2009 06:45 PM
Sold Out
13
Jul 6, 2008 09:56 AM
Mychal71
Jul 8, 2007 07:32 AM
