97 Civic/B16a2 swap - OBD2 P2T versus P30 questions
K, so i have both a P2T ecu and a OBD2 P30 ecu I'm currently running the P2T for my b16a2 in my 97 hatch which runs perfect however it throws a p0453 code for the missing FTP sensor but for some reason its super hard to find one.... now i can run the P30 but when the engine is cold the engine will not idle but when warmed up runs perfect and engages VTEC sooner then the P2T and turns the cel off.. ive spent hours researching this problem but cannot find any info cause it seems that OBD2 P30 does not exist lol idk if the ecu is bad and i need it to pass deq but would like to run it daily so i don't have to look at a cel anymore.. i don't wanna convert to OBD1 since i don't plan on using hondata or tuning the car since it is stock.... if someone can help it would very much appreciated thank you.
if you want to run the p30, you will need to get a throttle body off an obd1 b series or automatic obd2. 96+ MT b series throttle bodies do not have a FITV.
hard to find a FTP sensor because it's on the gas tank of 99-00 civics.
so i did more research on this problem and found that i need to get the dizzy pinout for the p30 anybody know where i can find this?
karmaworks199
Nov 8, 2015 05:27 PM
90Rexx
15
Feb 6, 2010 09:20 PM
