EK rear disc question
Old Aug 2, 2012 | 08:26 PM
Spitz911's Avatar
Default EK rear disc question
Ok so i just bought a rear disc conversion (or part of it at least) i just need a master cylinder e brake cable and brake lines... Now ive done some research and found that since the rear discs are from a GSR i need GSR brake line which is fine but.. Can i use an Si master cylinder/proportioning valve and an Si e brake cable with the GSR brakes? Any info would help thanks.
Old Aug 2, 2012 | 08:50 PM
98civdx's Avatar
Master Detailer
Default Re: EK rear disc question
It would definetly help if we knew what kind of car it is.
leave the MC alone!
Old Aug 2, 2012 | 08:54 PM
Spitz911's Avatar
97 civic hatch
Old Aug 2, 2012 | 09:13 PM
98civdx's Avatar
Master Detailer
Leave the prop valve and MC alone.
99-00 SI e brake, and brake lines. Integra brake lines would work too.
Old Aug 2, 2012 | 09:16 PM
Spitz911's Avatar
awesome thank you!!! that will save me time trying to find that stuff... now ive also heard that EX e brake cables work too is that right?
Old Aug 2, 2012 | 09:18 PM
98civdx's Avatar
Master Detailer
No, drum cables are diferent. It needs to be from a disk car.
Old Aug 2, 2012 | 09:21 PM
Spitz911's Avatar
i thought EX was 4 wheel disc since its the model below the Si
Old Aug 2, 2012 | 09:45 PM
98civdx's Avatar
Master Detailer
Not that I know of. I was under the asumption that only the 99-00 SI got rear disk. For 96-00 anyways.
Old Aug 2, 2012 | 11:10 PM
Kohen's Avatar
Wut... no.
I've had two EX's, neither with disc brakes. Maybe I got jipped.
Old Aug 2, 2012 | 11:18 PM
98BlackExCoupe's Avatar
Let me know how it turns out will you? I'm gonna do the same thing in a couple weeks. Can't wait.
Old Aug 2, 2012 | 11:29 PM
Kohen's Avatar
What do you wanna know? Hundreds of people have done the conversion. It's spendy. It doesn't improve braking THAT much. It's more expensive to work on and you have to maintain it more than drum brakes. It just looks good.
EDIT: Reasoning for a rear disc conversion not doing much is that only ~15% of your braking power is in the rear. If you want a real notice in braking power, do a front disc conversion, where ~85% of your braking power is. Or maybe consider a bigger rotor conversion. Like some S2K rotors.
Old Aug 3, 2012 | 12:06 AM
Spitz911's Avatar
Word will do just gotta pick up the last parts
Old Aug 3, 2012 | 12:55 AM
Spitz911's Avatar
Originally Posted by Kohen
Wut... no.
Im probably wrong i just based it off what i heard btw did u go to capital high school? Cause i might know u haha
Old Aug 3, 2012 | 01:33 AM
Kohen's Avatar
Nope. Graduated at Tumwater
Old Aug 3, 2012 | 07:11 AM
kyden's Avatar
your oem master and proportioning valve will be fine. e-brake cables from an si. rear brake lines can be from an integra or civic si, doesn't matter since they're the same.
GeoMetry
Nov 11, 2015 09:20 AM
'96-EJ6Hatch
32
Mar 18, 2012 05:21 PM
feriotypeR
Aug 15, 2009 12:12 PM
Cboi
Mar 13, 2007 11:26 AM
enrique
Feb 26, 2004 05:17 PM
