Where can I buy an intake flange for a b16?
Old Aug 2, 2012 | 03:44 PM
mini-angus96's Avatar
Default Where can I buy an intake flange for a b16?
I am looking for a b16 intake flange (stainless steel preferably). I need to make a custom intake to fit my application but cannot seem to find anyone selling one...
Old Aug 2, 2012 | 04:30 PM
chewyv's Avatar
pm4nudes
Default Re: Where can I buy an intake flange for a b16?
Just go to any exhaust shop. Not sure why you would use a flange though.
Old Aug 2, 2012 | 06:07 PM
No, not a gasket or flange for the exhaust... An actual say 3/8 inch thick piece of metal (flange) that has the intake ports bored out of it so I can weld up my own intake manifold for my conversion. This piece is essentially the bottom flat part of the stock manifold that bolts to the block with all of the intake pipes cut off. The stock one does not fit and I looked around for another one that is shorter and has the right dimensions but they will all hit the firewall so I need to make my own intake.
Old Aug 2, 2012 | 06:08 PM
doood's Avatar
been there done that
cut the flange off the manifold you have now
Old Aug 2, 2012 | 07:01 PM
chewyv's Avatar
pm4nudes
Then all you need is a machinist to cut a piece of metal for you. I'm sure 90% of specialty shops will have a metal fab/machinist to custom make you whatever you want after you give them the dimensions.
Old Aug 2, 2012 | 07:18 PM
Nickeg9Ej1's Avatar
http://straightlinespecialties.com/s...products_id=45
Old Aug 2, 2012 | 07:31 PM
^ that's almost exactly what I want except not 200 bucks from a wonky website... The one on my manifold i can cut off but I would rather buy one and have it be perfect than some grind/hack job of me destroying mine. That's all
Old Aug 3, 2012 | 10:42 AM
Nothing?
Old Aug 4, 2012 | 07:07 PM
bump
Old Aug 4, 2012 | 10:47 PM
jbpnoman's Avatar
Let me help you out here.
B16A intake manifold flange
Since you didn't tell us which B16 you're using, thats the best I can do. On the first page, I see billet, stainless, aluminum, and steel.
TurboEG6262
Welding / Fabrication
Mar 9, 2013 03:16 PM
jmeyer99
Jun 29, 2012 10:24 AM
Johnny O A20 KIller
Apr 16, 2006 02:57 AM
Justin Olson
14
Jun 13, 2005 02:59 AM
