Where can I buy an intake flange for a b16?
I am looking for a b16 intake flange (stainless steel preferably). I need to make a custom intake to fit my application but cannot seem to find anyone selling one...
Re: Where can I buy an intake flange for a b16?
No, not a gasket or flange for the exhaust... An actual say 3/8 inch thick piece of metal (flange) that has the intake ports bored out of it so I can weld up my own intake manifold for my conversion. This piece is essentially the bottom flat part of the stock manifold that bolts to the block with all of the intake pipes cut off. The stock one does not fit and I looked around for another one that is shorter and has the right dimensions but they will all hit the firewall so I need to make my own intake.
pm4nudes
Then all you need is a machinist to cut a piece of metal for you. I'm sure 90% of specialty shops will have a metal fab/machinist to custom make you whatever you want after you give them the dimensions.
^ that's almost exactly what I want except not 200 bucks from a wonky website... The one on my manifold i can cut off but I would rather buy one and have it be perfect than some grind/hack job of me destroying mine. That's all
Let me help you out here.
B16A intake manifold flange
Since you didn't tell us which B16 you're using, thats the best I can do. On the first page, I see billet, stainless, aluminum, and steel.
Justin Olson
Welding / Fabrication
14
06-13-2005 02:59 AM
