B16a2 in 90Teg??? HELP!
ok my cousin is swapping a b16a2 in a 90 integra Ls....
we are using his 90 Ls cable tranny...what clutch would he need to use? he's buying a clutch masters clutch and a flywheel too...so what would he get it for...90Ls or 99b16a2?
also...what mounts would we use....his stock Ls mounts???
ECU??...his car is 1990 which is obd0?? what ecu would he have to get?
thanks alot!!!
thanks alot!!!
clutch:
he needs to buy one for a 90-91 teg because it has a smaller spline (25mm) than the 92+ tegs (26 mm).
mounts:
the car came with a b-series motor so he wont have to buy new mounts.
mounts:
Here are the different ecu's...
http://www.hondaswap.com/reference/index.php?mode=ecu
Either one of those ecus should be ok. He might cosider getting a chipped P28 if he is not on a tight budget, that way you can do away with the knock sensor and second O2 sensor (I think the JDM motors have 2 O2's
its a B16a2 from a 99 Si...i think i posted that in the add above...he got a good deal on it from a junkyard...$1000 for motor...so thats why we are doing it...
thanks!
P28 ecu won't work...his car is OBD0 i believe...its a 90'
thanks!
my buddy, 91civicsi, is running his 95 gsr powered 91 hatch on a PM6 (civic si ecu) with the Zdyne One Wire Coversion...it runs great. Maybe your friend could check into that.
[Modified by Jeff C, 4:02 PM 10/17/2002]
dude saveyourself ALOT of heacaches
sell the b16a2 swap for about 2500$
buy a first gen b16 and use the 1300$ you saved to upgrade the cams, intake manifold clutch and flywheel.
check it out
<FONT COLOR="red">the reason we used this on my buddy's swap though is because we already had it.</FONT>
[Modified by Jeff C, 1:35 PM 10/18/2002]
globy123
56
Sep 16, 2018 05:53 AM
streetsold6teeny8
Mar 4, 2009 02:39 PM
