honda fit rims civic ek sedan rubbing issue
Old Jul 31, 2012 | 07:34 PM
93civicsedan's Avatar
Default honda fit rims civic ek sedan rubbing issue
Hello all, I picked up a set of '09 honda fit oem rims for my 2000 civic ex 4dr but I am having issues getting the rear rims to clear the upper control arms, they are rubbing for some reason. I didn't have this problem with my old Si rims so I am wondering if the difference in offset (Si's=45 and Fits=55) is the cause. That is the only difference between the two rims, both are 15x6 and I'm running the same size tires 195/55s also the car is lowered on tokico blues and h&r sport springs. Do I need some sort of spacer to fix this or do I need some aftermarket upper control arms. Thanks in advance for the help.
Old Jul 31, 2012 | 07:39 PM
redm3turbo's Avatar
Default Re: honda fit rims civic ek sedan rubbing issue
yes..offset means how far from the mount of the rim to the edge...so 55 is a little bigger.
you can use a spacer...just need a small one.
Old Jul 31, 2012 | 09:08 PM
98civdx's Avatar
Master Detailer
Do the wheels have clip on weights? If so remove them.
I needed 3mm spacer in rear for my tires to clear my trailing arms, and to remove the clip on weights.
Old Aug 1, 2012 | 04:30 AM
I already had the clip on weights removed. but it still is very close to the uca, there isnt even a full finger gap in between. anyone know of a good site to pick up thr spacers? thx.
Old Aug 1, 2012 | 10:11 AM
98civdx's Avatar
Master Detailer
Wheel/tire store should carry them. If not ebay.
Old Aug 1, 2012 | 07:49 PM
Would a 5mm spacer do the trick or do I need more or less? Thanks.
Old Aug 1, 2012 | 07:56 PM
d15bvtechatch's Avatar
that should work. 1/4 inch
Old Aug 1, 2012 | 08:34 PM
98civdx's Avatar
Master Detailer
I used a 3mm universal spacer and it was enough. (granted it was my tires rubbing my trailing arm bushings.)
Be careful to not go too big or you will need to get extended studs. You will want a minimum of 6 full turns.
Good luck.
Edit- 5mm would be the MAX i used on stock studs.
Jay Moreno
Nov 16, 2016 04:50 AM
pr_boricua9
Suspension & Brakes
13
Sep 29, 2016 09:45 AM
Mishako129
Apr 14, 2013 08:43 PM
GOTRICE12
Dec 20, 2012 09:58 AM
