slim fan question
Old Jul 31, 2012 | 05:23 PM
KtHaNxBai's Avatar
Default slim fan question
ok, my car has a/c i want to mount the slim fans infront of the radiator..which way should they spin??? another question, i assum that the teggy have 2 fans..1 for radiator and one for condensor.. am i right?? if so how should i make the fans spin if the fans are infront of radiator..and behind condensor.
Old Aug 1, 2012 | 11:57 AM
EJ8_Man's Avatar
Default Re: slim fan question
I had the same dilemma with my B18C swapped Civic. Push or pull was the question, I went with pulling the air through the radiator and into the engine bay. Even if you are installing the fans outside of the engine bay it seems natural to me to pull the air in taking into consideration at very low speeds, when the engine needs the fan to help with cooling, there will still be air flow over the front of the car which would counter the flow of the fan if it were pushing the air out of the engine compartment. The Integra radiator is full sized and the A/C radiator sits in front of the coolant radiator (at least on my 95 LS) so both fans will act to cool the engine coolant and A/C radiators. I can't remember if the A/C radiator is full sized also, which means that one fan may perform cooling for both, while the other specifically works over the coolant portion
stevenr2894
Apr 14, 2013 12:49 PM
julianbc2
Jun 28, 2010 12:31 PM
VTEC_PRODUCTION
Aug 17, 2009 11:03 AM
gs_rbaby
Jun 2, 2009 01:55 PM
ImPuLsIvE
Nov 2, 2007 08:27 AM
