Brake fluid question
Old Jul 29, 2012 | 04:20 AM
Hondatypr636's Avatar
Default Brake fluid question
Im gonna be putting extended wheel studs on my car. I figured I will go ahead and upgrade my master cylinder to 1in and put new brake fluid.
So my question is how many quarts do i need to refill the whole system?
Old Jul 29, 2012 | 04:38 AM
beecee18's Avatar
Default Re: Brake fluid question
Dont see you needing more than 1-2 quarts,
Not sure though, I would have to look in the service manual to see if they specify total brake system fluid capacity.
Old Jul 29, 2012 | 04:42 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Depends on how much you have to bleed the system to flush out the old, and to get all the air out after replacing the m/c.
I'd buy 2 quarts.
Old Jul 29, 2012 | 07:18 AM
I'd buy 2 quarts.
Thanks for the info Tom. I just noticed you sold the hatch. Damn would of liked to make an offer on that beast.
Old Jul 29, 2012 | 09:05 AM
redm3turbo's Avatar
and just a heads up....
once you open that brake fluid .... toss the left over. Brake fluid isn't stored well, and using old can harm your brake system.
Saw a guy at a dealership I used to frequent ruin his braking system because he used 6 month old fluid (or so he claimed) He wasn't happy about the price to fix though.
Old Jul 29, 2012 | 09:31 AM
Dontoh's Avatar
i wouldn't toss the left over though, it doesn't go bad instantly, but once it's open, it starts absorbing moisture from the air.. and water in your brake system can heat up and cause air bubbles.. anyway, save it for a bit cuz ya never know, but i wouldn't keep it more than a couple weeks. metal containers work best, if and only if its the original container..
also don't mix any brake fluids (DOT 3, 4, 5.1, 5).. im sure ya already know all this though, just figured i'd drop my 2 cents
good luck
Old Jul 29, 2012 | 11:28 AM
good luck
Thanks. I actually never really thought about it collecting moisture over time. Thanks for the input.
Old Jul 29, 2012 | 05:12 PM
Hidenplanvew's Avatar
You don't have to toss it just use it for other things.. Works really well for clearing yellowed headlights. Not as good as the kits you can get but will clear and remove most the yellow from headlights, not super clear but will allow more light through.
civic_driver
18
May 26, 2010 08:22 AM
93sivtec
May 18, 2007 05:42 AM
full Circling
Jul 12, 2004 06:12 AM
Elvis1977
Feb 18, 2004 02:39 PM
AdamITR
Feb 2, 2004 10:17 PM
