2.75" Flange on 00 Civic Cat
Old Jul 28, 2012 | 01:06 PM
Teh Boss's Avatar
Default 2.75" Flange on 00 Civic Cat
I have a Skunk2 Megapower with 70mm/2.75" tubing from the cat all the way to the can. The problem I have is, the B-pipe flange will not match up with the prewelded bolts on the cat flange. The flange on the Megapower is just too big. I'm going to be buying an Invidia test pipe within the next few days anyways, I'm wondering if I should just order a 2.75" stainless flange, cut the 3 bolt flange off the test pipe, and weld the new 2.75" flange to the test pipe? Or does anyone have an easier solution for me?
Old Jul 28, 2012 | 01:10 PM
Fnix's Avatar
Default Re: 2.75" Flange on 00 Civic Cat
take it to a muffler shop, they can usually rig something up, at least here in germany
Old Jul 28, 2012 | 01:17 PM
Teh Boss's Avatar
Yeah, I just hate having to take **** as simple as this to a muffler shop
Old Jul 28, 2012 | 02:16 PM
JuggerNaut-CTR's Avatar
As simple as this? You seem confused on what to do. If you have a welder, buy the flanges you need and do the work yourself, or if you actually want it simple...take the test pipe and piping to a exhaust shop, put it in their hands, and say...put it on.
Old Jul 28, 2012 | 02:37 PM
Teh Boss's Avatar
I'm not confused. I'm just trying to see if anyone has done this differently. I'll just mig the new flange onto the test pipe then.
Old Jul 28, 2012 | 04:07 PM
How else would you possibly run exhaust? Metal tape?
Old Jul 29, 2012 | 09:52 AM
Teh Boss's Avatar
No, that's not what I'm saying. I wanted to see if getting new holes drilled in the cat flange would be easier, or if i should get a reducer welded to the 2-3/4" tubing and then put a 2-1/4" flange welded to the reducer. I was just thinking that the new flange is gonna be way too big for the cat tubing, its just going to slide over the cat tubing. I'm either going to have to tack a few welds on and then fill the excess space with a buttload of weld or just buy a reducer, and that is what answer I am looking for right now.
TheCrimsonGhost666
Jan 9, 2012 05:42 PM
90DALS
Sep 11, 2004 11:02 PM
SB97civic
Dec 31, 2003 11:10 PM
-Whitey-
Jan 26, 2003 04:57 PM
Etylorcen
Oct 23, 2001 11:55 AM
