stereo randomly cutting out and coming back on, maint light starting to flash
Old Jul 27, 2012 | 10:16 PM
EJ8_Enthusiast's Avatar
Icon2 stereo randomly cutting out and coming back on, maint light starting to flash
2004 base rsx, installed the radio well over a year ago never had any problem, now recently it will just cut out, come back on.. a few times, then not do it for days.
should I have my battery and alternator tested? What else can I check
Thanks
Old Jul 28, 2012 | 05:28 PM
mikekh10a's Avatar
Default Re: stereo randomly cutting out and coming back on, maint light starting to flash
it won't hurt to go to autozone to have your starting system checked
also you should pull out your radio and check the condition of your radio harness to make sure there are no exposed wires.
Old Jul 29, 2012 | 07:50 AM
after a google, the maint light flashing 10x at start is hopefully just regular interval, so many miles and it pops on, and can be easily reset.
I will pull the radio out and take a look, and get the starting system checked. Thanks
Old Jul 29, 2012 | 05:36 PM
Bad_dude's Avatar
Most likely a loose connection when you put in the new unit. Don't use the crimp connectors. Either use the posi-taps, twist the wires real good together, insulate with electrical tape and zip tie to secure the tape, or solder, which is best.
Sergeant Larson
Aug 2, 2017 01:11 PM
geomon
Feb 15, 2013 11:32 PM
LiveKing
Sep 30, 2009 07:46 PM
white_DB1
Mar 22, 2009 10:15 AM
