Suspension & Brakes Theory, alignment, spring rates....
Sleeves for Eibach shocks? EG Hatch
Old Jul 26, 2012 | 08:36 PM
thegame7's Avatar
Default Sleeves for Eibach shocks? EG Hatch
Currently have the Eibach Sportline kit (shocks and springs) on my EG hatch and am wanting to go lower once I switch to 15" wheels and 205/50 tires. I don't think I can trust ebay sleeves and Megan sleeves don't seem much better but they do advertise 325f/300r rates and are less than $150 from TH Motorsports.
What sleeves would everyone recommended on a budget of less than $200? I did call Eibach to get more information on the shocks and the guy I talked to recommended no stiffer than a 400lb spring on their shocks.
Old Jul 26, 2012 | 10:54 PM
98civdx's Avatar
Master Detailer
Default Re: Sleeves for Eibach shocks? EG Hatch
Megan coilovers suck, they were on my buddy's civic. Super bouncy, and the coating flaked off in a few months.
IMO, there is no quality sleeve for under $200, unless you find used Ground control's. I do recommened you stick with Ground control's. They go for about $330 new.
Old Jul 27, 2012 | 06:39 AM
type_r_ek's Avatar
if your on a budget then just get eibach sportline springs, it lower enough that youll like it, or save up and get gc sleeves
Old Jul 27, 2012 | 08:54 AM
98civdx's Avatar
Master Detailer
^ He's already on Sportlines.
Old Jul 29, 2012 | 07:29 PM
thegame7's Avatar
I was afraid I'd get the Ground Control answer but it's highly probable that those are the only option. Unless I put H&R Race springs on it which aren't adjustable but will sit lower than Sportlines.
Old Jul 29, 2012 | 08:31 PM
98civdx's Avatar
Master Detailer
H&R race springs have pretty high spring rates. In fact, I am pretty sure they are higher then 400lb
Old Jul 30, 2012 | 07:33 AM
Jackson's Avatar
I used the GC kit with my Eibach Pro Dampers last year. It held up very well for street use. I wouldn't recommend any other type of coilover sleeve kit other than Ground Control.
Old Jul 31, 2012 | 08:53 PM
thegame7's Avatar
That's great news! What spring rates did you run?
Old Aug 3, 2012 | 01:03 AM
92civiceg9gsr's Avatar
With those Eibach shocks you should use the standard rate (or close to it) GC springs.
thegame7
Suspension & Brakes
Jan 24, 2012 09:14 AM
CivicSi95
Suspension & Brakes
Jun 29, 2009 11:12 PM
hondaguyflozy
Dec 13, 2008 09:41 PM
koulaid
Suspension & Brakes
Nov 18, 2006 06:10 AM
DeadLock23
Apr 2, 2003 03:41 AM
