oil leak on my transmission
Old Jul 26, 2012 | 07:56 PM
Cameron k.'s Avatar
Default oil leak on my transmission
i have a 95 civic, and theres been some oil leaking on my transmission from somewhere, i went and had it fixed, spent alot of money and its still leaking i know you cant give an exact answer based on a picture but if you know anything please help me out.
Old Jul 26, 2012 | 07:58 PM
Fliptard's Avatar
Default Re: oil leak on my transmission
o-ring on the distributor?!?
Old Jul 26, 2012 | 07:59 PM
Former User's Avatar
Looks like a classic case of leaking distributor. Also check the VTEC solenoid, if you have one.
Cameron k.'s Avatar
i honestly dont know, im just now getting into hondas as you can tell, how can i check that?
Old Jul 27, 2012 | 07:03 AM
DanCan'tSwim's Avatar
Post Re: oil leak on my transmission
O-ring, maybe Valve cover, most likely O-ring.
look at where your distributor meets the engine head. there SHOULD be a rubber ring between the two, however you may not be able to see if without removing the Diistriburor (careful not to spill oil). I just replaced mine two weeks ago because it was leaking ( all over my tranny ). I bought the ring for 1.99 at my local Honda dealership. Also check the valve cover bolts to see if they are loose.
after all that check your dipstick and add oil if need be.
Old Jul 27, 2012 | 07:07 AM
jugding by the D16Z6 stamp on your engine I'm gunna say you do have VTEC. check that too. it's attached to the head aswell. (back left) and should have a green sensor on it.
Old Jul 27, 2012 | 08:34 PM
Cameron k.'s Avatar
see anything wrong with the valve cover?[IMG]
Old Jul 27, 2012 | 08:40 PM
Buy distributor O-ring from Honda dealer
Remove distributor.
Replace O-ring and coat with oil.
Install distributor.
Adjust ignition timing.
Old Jul 27, 2012 | 08:41 PM
Cameron k.'s Avatar
see anything wrong with my valve cover?http://www.flickr.com/photos/8364277...in/photostream
Old Jul 27, 2012 | 08:53 PM
EJ8mike's Avatar
It's hard to tell if your valve cover is leaking by just looking at those pics.
You should replace distributor o-ring first, then valve cover gasket if needed...valve covers like to leak around the corners if you dont use gasket sealer.
Have you taken ur valve cover off lately?
Old Jul 29, 2012 | 12:45 PM
Cameron k.'s Avatar
no, never have, should i?
D16W9
Honda Civic (2001 - 2005)
Nov 7, 2014 01:48 PM
Ash Ketchum
Jun 26, 2011 03:00 PM
jam36a
Aug 19, 2006 09:56 AM
civicDX2178
Jul 17, 2006 11:27 PM
slowpokesi
Jan 27, 2003 08:26 AM
