Overheating at a stop lights
Old Jul 25, 2012 | 06:24 PM
Aaron Cayabyab's Avatar
Default Overheating at a stop lights
Honda Civic LX 1998
Everytime im at a stop light my heat idle arrow starts to rise up(overheat), but then when i start driving it slowly goes back down. Or sometimes when i drive slow it begins to overheat. Does anyone know why this happens? I appreciate any inputs and tips
Old Jul 25, 2012 | 06:37 PM
Fliptard's Avatar
Default Re: Weird overheating issues.
B20, yes. use google and search. overheating - check your coolant level? change your thermastat
Old Jul 25, 2012 | 07:15 PM
Dc4LsTeG's Avatar
EK9
Are your fans turning on?
And yes a b20 will fit, you could've found out with a quick search
Old Jul 25, 2012 | 07:46 PM
Yes, Coolant checked, Thermosat checked, water pump checked, fans working checked!
And I asked because I did research but I didn't find any saying it would only said D-Series
But let's forgot these question now, I just didn't want to make two threads but thanks for your answers.
Now back to the main question I have changed n checked everything and my car still overheats!
Old Jul 26, 2012 | 01:43 PM
Fliptard's Avatar
Make sure the system is all bleed out.
Old Jul 26, 2012 | 03:38 PM
Former User's Avatar
Default Re: Overheating at a stop lights
Please summarize the technical problem in the thread title - edited.
Old Jul 26, 2012 | 08:21 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Please elaborate on how you checked these. Is your fan running when your at a stop because it doesn't sound like it
Old Jul 26, 2012 | 08:25 PM
If this^ were true, then you'd know what the problem is and would be fixing it now.
Old Jul 26, 2012 | 08:39 PM
TypeRfit's Avatar
RESIDENT
By any chance do you have slim fans? Are the fans moving air in the proper direction (should be sucking air in from the front of the car not trying to blow it out of the front) Does your coolant level drop? Is there coolant in your oil? Is your thermostat stuck? Have you had your radiator checked (calcium buildup with clog a radiator and will not flow sufficient coolant through it)
Old Jul 26, 2012 | 09:08 PM
CO671's Avatar
Try warming the car up to where it starts to overheat according to the temp gauge. Open up the hood and feel the lower hose. and the upper radiator hose. The upper hose is obviously on the upper side of the radiator right next to the radiator cap and connects to the engine head. The lower radiator hose connects from the bottom of the radiator up to the left side of the intake manifold and engine head.
If the lower radiator hose isn't warm like the upper hose, it's likely to be a thermostat problem.
Old Jul 26, 2012 | 09:53 PM
Yes my fan does turn on when im at a stop or when car begins to heat up, i checked if the fan still worked by simply jumping it to a 12v source(Car battery)
Trust me i tried everything and i even took it back to the shop that repaired my head gasket and got it back and the same day it over heated
Nope not that i know of and coolant level is good i make sure the radiator is topped but i dont lose coolant.
Top and bottom hoses are both warm, Replaced the thermostat (Twice)!
Old Nov 29, 2012 | 10:53 AM
jeanettechr's Avatar
My '98 Honda Civic LX is having same overheating problem AND now the fuel system is acting up (misses on acceleration). Anyone able to help me? PLEASE!
Old Nov 29, 2012 | 11:08 AM
EsotericImage's Avatar
Retired Moderator
Please start your own thread with detailed information. this thread is months old and im sure the problem has been fixed by now.
Old Nov 29, 2012 | 03:00 PM
dc4b20's Avatar
pressure check your cooling system
kurs
Oct 15, 2009 07:41 PM
som3on3_10
Mar 29, 2006 03:31 PM
FAWKeveryb0dy
Aug 10, 2005 05:58 PM
Voom
Aug 19, 2002 10:07 PM
