No power to main relay + code 31 & 41
Old Jul 24, 2012 | 04:30 PM
bwfisherman09's Avatar
Icon2 No power to main relay + code 31 & 41
iv been looking for over an hour. Hopfully someone can point me in the right direction but i am a proud owner of a 1994 honda civic b16z6.
Problem is i bought this car not knowing some guy rigged up his own alarm system which is where the problem only begins.
I noticed i have no power to my main relay first clue was that the previous ower has the fuel pump wired into the radio fuse and the instroment panel wired around the back up light fuse? Everything works so i wasnt going to play around with it untill today.
I pulled the plugs on the car and it running lean as hell and had some codes so i ran the codes which came out to be a 31 and 41.
Any help would help me from pulling any more hair then needed
Old Jul 24, 2012 | 05:25 PM
Former User's Avatar
Default Re: No power to main relay + code 31 & 41
What ECU? Auto transmission?
Old Jul 24, 2012 | 08:33 PM
jbpnoman's Avatar
Also, D16Z6, not B16Z6. The second doesn't exist.
Old Jul 25, 2012 | 01:11 AM
It is the stock ECU p06 but im not 100% if it is the P06 ill have to check after work and manual trans.
Sorry about that yes its the d16z6.
Old Jul 25, 2012 | 05:04 AM
You are reading code 31 incorrectly. Post a video of the blinking CEL.
Old Jul 25, 2012 | 05:18 AM
i have the p28 just ran out to the car and checked
Old Jul 25, 2012 | 05:19 AM
it fashes a code 31 then it just repetadly flashes 41 sorry i told you the wrong ecu do you still need need a video?
Old Jul 25, 2012 | 05:22 AM
Yes. Jump the connector and start the video as you turn the key to ON(II). In the video, let the blinking CEL run through a few cycles.
Old Jul 25, 2012 | 05:42 AM
ill have it up around 12:30 1 o'clock thank you
Old Jul 25, 2012 | 09:04 AM
you were right the only code i have now is 41
Am i kicking code 41 because my main relay is not getting power?
Does the o2 sensor run through that relay?
Old Jul 25, 2012 | 09:09 AM
Does the engine now start?
Does code 41 repeat over and over again or does the code blink from the CEL once and then the CEL remains on steady?
How do you know your main relay is not getting power?
Old Jul 25, 2012 | 09:54 AM
Yes car runns just runs leans as hell
Code 41 repeats over and over
I know my main relay doesnt have power because the fuel pump is spliced into my radio fuse as is my instrument panel is spliced into my backup light fuse before they go into my main relay under the dash
Old Jul 27, 2012 | 03:39 PM
o2 sensor was bad no continuity in the o2 sensor replaced it with a new one cars running good
biotech0123
Apr 24, 2011 02:33 PM
DCRB
Sep 26, 2010 06:22 PM
builtsinglecam
Sep 24, 2009 09:37 AM
jdmmostwanted
Jan 23, 2008 12:13 AM
charjacq
Mar 11, 2004 02:06 PM
