97 honda civic dx swap huge wire issue
Old Jul 24, 2012 | 07:57 AM
Del_Slo_b16's Avatar
Default 97 honda civic dx swap huge wire issue
Hey guys, I have a 1997 honda civic dx with a b16 swap in it. I got it about 8 days ago and found out that the wiring in it is absolutely rediculous...i have no speedometer and my check engine light flashes. I try to hook up a code scanner to it but it doesnt come on and i found out that it only has 5 wires hooked to it... i posted pictures and you can see what im talking about. Also the ecu is a p30 but there are wires everywhere also and idk what im doing...Obviously i am gonna get alot of negative responses because i dont know but i dont expect to fix it with just questions i am asking i only want to get an idea of what i can do or what these wires are...thanks to everyone in advance for the help.
random wires that were hanging
this is the obd that i hook the scanner into
the wiring under the dash
and this is what the ecu looks like
Old Jul 24, 2012 | 08:03 AM
Former User's Avatar
Default Re: 97 honda civic dx swap huge wire issue
The P30 ECU is OBD1 and your car is OBD2. This renders the ODB2 code reader useless as it cannot read codes from an OBD1 ECU.
You can pull codes by jumping the service connector.
Old Jul 24, 2012 | 08:08 AM
How would I go about doing that??
Codes sticky at top.
Old Jul 24, 2012 | 08:13 AM
ok thanks. i will try that as soon as i get home. any advice on the other wiring???
Old Jul 24, 2012 | 08:14 AM
Install new wire harnesses?
Old Jul 24, 2012 | 09:23 AM
kyden's Avatar
the random drivers side wires looks like it would have been for an alarm.
i myself would get a new engine harness as yours is a mess.
Old Jul 24, 2012 | 11:02 AM
kwijibodavid's Avatar
looks like he needs the dash harness not an engin harmess looks like they were to cheap to buy an obd2-1 jumper harness
Old Jul 24, 2012 | 11:27 AM
Unfortunately Idk how to replace any of that....
lsvtec63
13
Jan 6, 2009 11:58 AM
convic23
12
Oct 27, 2006 06:47 PM
importboi22
May 31, 2004 02:31 PM
b16acrxer
Nov 30, 2003 04:54 PM
Chris
Jan 5, 2003 07:28 AM
