B16a won't start up after putting the cams back in
Old Jul 24, 2012 | 12:57 AM
aflyingpanda's Avatar
Icon2 B16a won't start up after putting the cams back in
I was going to trade my cams for another. Later did I know the decisions turned and flipped. I ended up installing my cams back in and in the process had to take the dizzy off cause the key wasn't lining up.
After reinstalling the cams and dizzy. I went to start it up and no luck. It cranks and all but seems like no spark. A buddy of mine told me I had fried the ignition coil from not disconnecting the negative from the battery. So I replaced the ignition coil as well as the rotor and cap. Still no luck. I am so stumped.
What could be the problem?
@RonJ@HT: It is a 96 ek sedan with a b16a swap.
Old Jul 24, 2012 | 01:17 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: B16a won't start up after putting the cams back in
Was it or us it not getting spark? Check cam timing?
Old Jul 24, 2012 | 01:25 AM
jbpnoman's Avatar
A) make sure you have your firing order correct.
B) are you getting bright white spark at all four plugs?
C) Did you somehow install something 180?
D) Did you check your ignition and mechanical timing after all of this?
Old Jul 24, 2012 | 08:57 AM
NVturbo's Avatar
O.G. triple O.G.
Did you set the motor to TDC prior to removing your set of cams? More than likely the TIMING is off. Set the crank pulley to TDC and work upwards to the cams/cam sprockets.
Old Jul 24, 2012 | 10:24 AM
Jimster480's Avatar
you probably messed up your timing, check spark at your plugs and check for fuel. Then report back.
Old Jul 24, 2012 | 04:54 PM
Timing should be right. because before i took off the cams, i put it to tdc, and put them back as is with the cam marking up at tdc. no spark from the spark plug wires.
my boy was telling me it could be the spark plug wires since they werent clicking on
Old Jul 24, 2012 | 04:58 PM
Former User's Avatar
You MUST provide information about your car and engine. Failure to do so may result in thread closure.
Old Jul 24, 2012 | 08:37 PM
jbpnoman's Avatar
That's mechanical timing. Check your ignition timing. There's also a DIY for how to test your distributor floating around here somewhere, you should do that as well.
Old Jul 24, 2012 | 11:14 PM
so you think it could be the ignition timing? could that be the reason why im not getting sparks to the plug wires?
Old Jul 24, 2012 | 11:19 PM
jbpnoman's Avatar
No, I think you aren't getting spark to any of your plugs because you fried something in your dizzy. That's why I pointed out that there are dizzy test DIY's floating around here that you should read. Check the stickies. I say you need to check your ignition timing because you said you were ripping things apart, and setting ignition timing is part of putting those things back together correctly.
Old Jul 24, 2012 | 11:25 PM
Dc4LsTeG's Avatar
EK9
Have you checked and cleaned engine grounds?
Old Jul 26, 2012 | 01:26 AM
Thank you everyone for posting and helping.
I finally just asked one of my boys, a honda mechanic, to come over and check it out.
Little did I know that the timing was off. Like 4-5 teeth off. He said it could have happened what I was putting the cams back in.
Old Jul 26, 2012 | 05:19 AM
Jimster480's Avatar
figured that it was
Global688
Nov 30, 2007 07:34 AM
XJamesX
13
May 29, 2006 10:10 PM
ben203
Mar 12, 2005 02:07 PM
wangan_DA9
Nov 1, 2004 06:39 PM
baruba
Sep 27, 2003 03:43 PM
