'99 F23A1 top dead center question
First time changing a timing belt and had to pull the belt off and redo and the cam moved when I looosened the crank bolt. I had TDC earlier but now not sure. If I rotate counter clockwise I can get TDC on the crank and cover but the cam UP is pointing down. Am I missing something or shouldn't I have TDC on both the crank and cam when the belt is on? When I rotate crank again I can get both to TDC but that doesn't feel right to this first time timing belt changer. Thanks for the help!!
zrs6v4
10
Jun 10, 2017 06:24 AM
goota
Aug 22, 2009 07:38 AM
