P0141 on 98 Civic with b16A2 Engine with GSR ECU
Old Jul 22, 2012 | 06:50 PM
Joseph Diaz's Avatar
Default P0141 on 98 Civic with b16A2 Engine with GSR ECU
Hello. I have this particular CEL P0141 code. I have a 98 Civic EX with B16A2 engine and a GSR ECU. I used a rear 02 Sensor for a 99 SI to clear the code but it is still there. Should I be using a GSR rear 02 Sensor in order to clear the code because I'm using a GSR Ecu?
Help is much appreciated. Thank you in advance.
Old Jul 22, 2012 | 08:07 PM
Former User's Avatar
Default Re: P0141 on 98 Civic with b16A2 Engine with GSR ECU
Check whether the sensor heater gets voltage and measure its resistance.
Old Jul 24, 2012 | 07:06 PM
I finally got it fixed. The 02 Sensor wiring harness to the ECU wasn't hooked up. I extended the 02 sensor wires going to the ECU. Did some search in here and the internet and found which wires to tap on the GSR ECU. Started the car and no more CEL!!
DailyDriven259
Sep 2, 2009 03:10 PM
hatchy92
Feb 2, 2004 12:57 AM
hatchy92
Feb 1, 2004 10:09 PM
Nerv2g
Aug 10, 2003 08:42 PM
satan_srv
Dec 4, 2002 03:56 PM
