96 civic 1.6 no start
Old Jul 20, 2012 | 06:02 AM
veja's Avatar
Default 96 civic 1.6 no start
did some tests without obdII , replaced main relay, new fuel filter and had 40psi, spark at the plugs checked grounds, new throttle body 2 years ago, ran great. How do I get codes without obd II? What else should I try.It started once after a long cranck, ran rough then smoothed out, I thought it was air in the filter. Next day no start, also checked ignition, ohm`d out ok...
Old Jul 20, 2012 | 06:05 AM
Former User's Avatar
Default Re: 96 civic 1.6 no start
Click the codes sticky at the top.
Old Jul 20, 2012 | 06:39 AM
veja's Avatar
I don`t understand sticky at the top, sorry
Old Jul 20, 2012 | 06:41 AM
See gray highlighted threads at top labeled Sticky.
Old Jul 20, 2012 | 06:47 AM
veja's Avatar
OK Ron thanks, the mind is a terrible thing sometimes
Old Jul 20, 2012 | 10:12 AM
Jimster480's Avatar
Air in the filter? Once you have checked the codes let us know what they are.
Old Jul 20, 2012 | 11:42 AM
veja's Avatar
went out a got and obdII, o well. anyway...got 3 codes,, P113, 1298 and 420, last 2 being emissions. I followed directions to reset ECM/PCM fuse 7-5 back up checked again and got zero codes tries to start and sputters trying to start... I smell gas thats all. Am I looking for a broken wire some where else ?
Old Jul 20, 2012 | 11:48 AM
Check for bright white spark. See my signature.
Check the mechanical timing. See FAQs sticky.
Old Oct 13, 2013 | 12:57 AM
just2dope4daygo's Avatar
this guide saved me a lot of hastle n question asking. thanks a lot for compiling this useful information
masterofnone
Dec 17, 2013 05:38 AM
Jamal231231
Nov 25, 2013 09:04 AM
kevinm1981
Jul 12, 2009 01:40 PM
crunked4477
Aug 5, 2004 11:44 PM
