trans has no gears
Old Jul 19, 2012 | 09:04 PM
Jitterbug831's Avatar
Icon2 trans has no gears
ok so i have a 92 civic that i just swap a b18b in to and also i made the car a 5 speed. so today i was going to take it out for its frist drive and when i went to put it in to gear nothing happens (no nosie, tires wont move, no gears work)i i disconnected the shift linkage and put the gear in by hand and still nothing. any ideas what can be wrong??? bad trans or am i missing somthing, also i have tried to search for info but cant find any with this problem
Old Jul 19, 2012 | 09:06 PM
Default Re: trans has no gears
o i forgot when i put in gear the shifter is verry loose like if it was in nutral
Old Jul 19, 2012 | 09:16 PM
jbpnoman's Avatar
Was the transmission in working order before you installed it? It sounds like either the shift selector is broken, or the input shaft isn't seated in the motor correctly.
Or you forgot to install the clutch and/or flywheel, but that's a bit more than...silly.
Old Jul 19, 2012 | 09:29 PM
dont know if the trans was working i got of some guy that said that its was working . any way i can check the shift selector?
Old Jul 19, 2012 | 09:44 PM
jbpnoman's Avatar
Take the transmission apart.
Before you do that, I would take the transmission off the car, try to put it in gear, and see if you can get the output splines to move when you rotate the input splines. It's also possible something's just stripped.
Old Jul 20, 2012 | 06:15 AM
Former User's Avatar
Axles fully inserted into transmission?
Old Jul 20, 2012 | 06:31 AM
Yes I checked the axles. When the car is runnig I try to put it in gear and nothing happens no grinding it's sames like its still in neutral
Old Jul 20, 2012 | 10:15 AM
Jimster480's Avatar
sounds like the gear selector fork inside the transmission is broken. Thats why I always test transmissions before buying them. check the gears and the shaft.
Old Jul 24, 2012 | 06:18 AM
So what I found was a broken shifter selector replaced it with a new and the car runs grate thanks for all your help
eglude
20
Jul 1, 2009 09:43 AM
ALL IMPORT
Sep 1, 2006 08:01 PM
Aquafina
26
May 21, 2006 11:07 AM
coachkellum
Sep 9, 2004 02:03 PM
arren123
Jul 3, 2002 01:33 PM
