Battery cut off swich
Old Jul 17, 2012 | 10:38 PM
JasonHi's Avatar
Default Battery cut off swich
does anyone have a diagram on how to correctly wire a battery cut off switch?
Old Jul 17, 2012 | 10:54 PM
turbohatch96y7's Avatar
Default Re: Battery cut off swich
You'll need a 12v solenoid.
A solenoid has a coil apply a negative to the coil and run a positive to your switch and then to your coil.
Run your battery positive to your solenoid. Then on the other side of the solenoid run that cable to your fuse box.
The solenoid has 4 terminalss total.
Old Jul 18, 2012 | 03:41 AM
MARC P's Avatar
^ no run the negative of solenoid to switch in rear and ground other side of the switch in rear.
Marc P
Old Jul 18, 2012 | 07:09 AM
MR.johnson's Avatar
This has been covered 1000s of times. Google is your friend.
Old Jul 18, 2012 | 09:47 AM
JasonHi's Avatar
I tried searching on google with no luck. Doesnt one side of the switch connects to the alternator or something?
Old Jul 18, 2012 | 09:57 AM
eg6 type-R's Avatar
google is ur bestfriend.. try typing in the right question u seek
Old Jul 18, 2012 | 11:10 AM
MR.johnson's Avatar
heres a spoon. now eat.
http://www.google.com/#hl=en&q=+site...w=1080&bih=611
Old Jul 18, 2012 | 12:02 PM
MARC P's Avatar
https://honda-tech.com/forums/audio-security-video-27/battery-cut-off-switch-2879950/
Old Jul 18, 2012 | 12:23 PM
Marc P
Either way WILL work...
Old Jul 18, 2012 | 01:17 PM
jdm inc's Avatar
http://www.t1racedevelopment.com/ind...utoff-kit.html
br8crumb
Jan 1, 2019 09:44 AM
julianbc2
Jan 25, 2009 12:11 PM
EJ1B18c
Nov 14, 2008 11:52 PM
flip1199
Jun 19, 2004 12:13 PM
2.2XDreams
May 6, 2004 12:53 PM
